Well, I got an order in for everything listed and unlisted that
http://drivebright.com/home/?s=taurus&post_type=product . First thoughts? IMPRESSED. Nice quality, great product. Straight forward directions and install, with fantastic results. I mean
Fantastic results. Since I got everything I will do a few write ups on the stuff
I will do the first one on the Puddle Light Kit as well as the license plate lights and the 6000K headlights.
Not sure where to start since they were all so easy. hardest thing to do was get my hand to the housing for the headlights.
Bright TRAX LED Puddle Light Pack (V4 EXTREME)
Tools required:
Thin Flat Head screwdriver
pair of pliers
Additional tools if you screw up:
Heat shrink
female spade
Heat Gun
Wire Strippers
Let me start by saying the $8-$15 upgrade of just taking the OEM product apart and swapping bulbs works! It will be brighter or at least more blue than the stock variation. Downside it the lens still diffuses too much light and brighter LED replacement does not hold a candle to how bright these things are. I mean they are like turn a flashlight on bright. They fade off in place of flicker.
All you do is take a flat head screw driver at an angle where you see the notch, then a light pry back towards the lens.
the assembly will basically fall out at that point
If your connectors are stuck you may have to take pliers on the metal portion never the line (wire) itself and pull.
Lightly attach the new light then put your hand on the door handle while holding the puddle light in the other hand to make sure the light comes on. If not the line is crossed. Just swap the plugs around. Check again. If good push connectors back in tight and put the tab back up in place.
DONE.
This mod should take fewer than 10 minutes for both sides total. Since I am a glutton for punishment I did the worst case scenario and "broke" the connectors off on one side. This was the worst thing I could think of that someone may do.
In case this happens you will need the second list of tools. You can get connector spades from everywhere. Wal-Mart, Harbor Freight are the cheapest though.
You will want to take a splice tool and cut off any remaining metal.
Strip about 3/4" of line with your wire strippper
Slide on heat shrink
Put on the spade and crimp with the stripping tool
Place the heat shrink over the crimp and heat it in place for a solid water resistant finish.
The above should take around 15 minutes if just dropping everything, forgetting where you laid down your tools etc. Took me about 4 minutes since I took pictures with it.
Worst case photo
Repair
Night
