lowered, by who
Started by cseverens, October 23, 2015, 11:26:44 AM
cseverens
so, I bought my sho used from texas. the original owner had it lowered, but I don't know which springs he used. I don't see a tag, but they appear to be more blue than black, but not bright blue. any ideas.
2013 Ford Flex Limited E/B
gladams
Quote from: cseverens on October 23, 2015, 11:26:44 AM
Call the owner or have the dealership call them.
2013 SHO mineral gray,  airaid CAI, Corsa exhaust
Traded the 2014 Fusion Titanium for........
2012 Mustang GT sterling gray 5.0 6sp manual. Roush CAI, Noise delete kit, lower control arm brace.
Livernois Motorsports
They are most likely one of the 2 big players in the lowering spring game which are H&R and Eibach.  Is there a problem with them that you are trying to find a new spring or something?
H&R's are blue in color. More navy if you will, and IIRC, a slight metal flake.
Here's an image of mine when they were NIB:
I no longer have the H&R's though, as I opted to upgrade even further, by rock'n the Megan Racing Coil Overs.
And the part numbers are stamped right on there, hopefully not worn out on the ones cseverens has.
ElvenSho
H&R for sure. Mine are same dark blue color and lowered about the same as your car.
nickstewartroc
Bpd,
With your Megans, do you notice a bit of a rocking back and forth when you come to a stop? I recently put the Megans on my 2011 and when I stop it kind of rocks back and forth... Otherwise they're great!
Quote from: bpd1151 on October 23, 2015, 11:41:46 AM
Current:
2013 Ruby Red Flex Limited EcoBoost, Unleashed Tuned, drop in filter
Gone but not forgotten: 2011 SHO Non-PP in Black Tuxedo Metallic - Catback, DPs, Stoptech Z23s, MDesign CAI, LMS Tune
Nope. No rocking. Strange.
Check your dampening settings. I suspect those are culprit.
cseverens
BigPelo
I have the Eibach kit. The coil springs are black and the car sits higher than yours. So I would say you have H&R.
Week-end family transporter: 2013 SHO tuxedo black, performance package, unleashed custom 94 octane tune, K&N Typhoon intake, 170F thermostat, 3 bar MAP sensor, SP534 spark plugs, 5000K HID Morimoto mini D2S projectors retrofit, tinted windows, Full LED lighting in and out, Eibach springs
Daily beater: 2002 WRX wagon swap JDM STi v7 20G'd
SHO T1M3
I believe there is only 1 option for the 2013's and newer at the moment. They have to be H&R's.
Megan's and Eibach's are only for 2010-12...
Sent from my SM-G900T using Tapatalk
Wilson
Eibachs work on 2013 as well, they're just discontinued.
With that said, that's definitely a H&R stance on the vehicle in question.
Wilson
2013 SHO (non-PP) Ruby Red Tintcoat
Leading Edge Tuning 93 Tune | 3 Bar MAP | 170* Thermostat | Airaid Intake | PPE 2.5" Downpipes | Snow Stage 2 Meth Kit | H&R Lowering Springs | 22" Falken RT-7M wheels | 265/35/22 Falken Ziex TZ05 tires
SHO T1M3
Quote from: Wilson on December 28, 2015, 06:00:44 PM
Wilson
Really?! Do you know the specs  (lowering amount, part#)?
I want to lower mine but not sure if 1.5" would be too much (I love on long island in NY).
Maybe I can find a set somewhere.
Wilson
Quote from: SHO T1M3 on December 28, 2015, 09:24:11 PM
Wilson
Good luck finding a set, I held out almost a year before I caved in and got H&Rs. Every now and then a set will pop up though, so just be ready LOL.
The part # is 35124. They are 0.8" up front and 1.1" in the rear.
In comparison,  H&Rs are 1.4" up front and 1.5" in the rear.
Looking back I love how my car sits on the H&Rs, but it would be nice sometimes to have that extra bit of clearance  (pulling into steep driveways / parking lots).
Wilson
