January 20, 2019, 01:59:22 PM
Author Topic: "How-To" Replace Brake Light Bulb(s) on 2010-2012 SHO's.....  (Read 9767 times)
Offline bpd1151
  • RotM Winner
  • Elite Member
  • : SHOcago S/W 'Burbs
  • Thank You
  • -Given: 1905
  • -Received: 1691
  • SHOGAZM
****The below posted "How-To" Tutorial was originally written by a member of another community, of which I am also a staff member.
The creator, and all proper thanks and kudos goes out to the user name (at this other community) known as: "Unknown_Driver".****
Moving along...... here it is, as appeared elsewhere:
Things you will need:
One 7/16 wrench
3057 replacement bulb
So step one, go to your nearest auto parts place and select your appropriate model year:
Locate the part in the billions upon billions of other replacement bulbs:
Head home or somewhere well lit i chose my driveway, now walk to the trunk and press the trunk release button on the remote (you could also get your fingers dirty by touching the button above the license plate):
On the side where the burnt bulb is you will find 2 plastic screws in the trunk, unscrew these:
Now gently pull on the carpeted trunk liner and fold it over to reveal the back of the tail light trunk area.
There are 4 x 7/16 bolts you will need to remove (you can just losen them with the wrench and spin them off with your fingers:
After all 4 bolts are removed you will need to pull off a bit of the rubber trunk weather stripping gasket (just a little to help take out the tail light):
Now attempt to pull out the tail light partly, you can push on the bolts form the rear while holding the light:
Now that you have the light out you can now twist out the socket from the tail light housing, and unplug the or pull out the bulb from its connector (just replace the bulb):
Now put everything back and in the reverse order and it should be good to go, you can also have someone push on the brake pedal or put an object on the brake pedal to illuminate the light to confirm it is working properly:
« Last Edit: November 18, 2017, 05:49:51 AM by ZSHO »
World's Highest AWHP SHO (Aug. 2014 - June 2016) & World's Fastest Ecoboost SHO to date! Details Here: http://www.dragtimes.com/Ford-Taurus-Timeslip-27985.html
  • Guest
Re: "How-To" Replace Brake Light Bulb(s) on 2010-2012 SHO's.....
« Reply #1 on: July 05, 2013, 12:17:29 PM »
Hooning is not a crime!  ;D
Offline EcoBrick Bob
  • Elite Member
  • : Naples, FL and Clear Lake, IA
  • Thank You
  • -Given: 64
  • -Received: 102
« Reply #2 on: July 05, 2013, 07:26:44 PM »
I tried this on my Flex... and now I have 2  broken taillights... Funny thing.. there was nothing wrong... The bulbs still work, but now I had to paint them red!
Naples, FL & Clear Lake, IA
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1180
  • -Received: 2727
« Reply #3 on: November 18, 2017, 06:01:38 AM »
 :sun: Let the PIC Restoration keep on shining.  Z  :sun:
« Last Edit: November 18, 2017, 06:05:37 AM by ZSHO »
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|Airaid-Dry-flow-CAI|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned @ 415whp-465wtq| Best Trap Speed of 115.54 mph|
* Featured Topics
* Recent Topics
Re: Ecopowerparts 09-14 F150 widebody kit
by 802SHO | Today at 12:19:16 PM
That looks bad a$$!  It's perfect in all the right spots...i...
Re: 2013+ intercooler install?
by StealBlueSho | Today at 08:48:15 AM
Any chance you could measure the core thickness? I'm curious as t...
Re: New Intercooler for Transverse 3.5L Ecoboost
by Jordan | January 19, 2019, 09:15:13 PM
For those skeptical of this upgrade I just made an installation video ...
by BoostfoSHO | January 19, 2019, 05:14:53 PM
New Alky pump ordered from www.Alkycontrols.comI emailed Julio over @ ...
Re: New member here transferring from other forums
by TonyTheTiger57 | January 19, 2019, 03:57:46 PM
No, there isn't a particular reason I like Fords.. It just happen...
Re: Ford Expedition & Lincoln Navigator
by ZSHO | January 19, 2019, 11:01:11 AM
2019 LINCOLN NAUTILUS RECALL ISSUED FOR 2,700 SUVSLincoln SUVs have pr...
MOVED: Toyota ecoboost
by ZSHO | January 18, 2019, 04:26:04 PM
This topic has been moved to Admin-Moderator only discussion.https://w...
Re: Throttle Body Motor assembly
by ZSHO | January 18, 2019, 06:22:19 AM
Feel free to start your own Dedicated thread here! Z https://www.ecobo...
Re: 2012+ timing job
by ZSHO | January 17, 2019, 06:28:58 PM
I believe so!  Z https://drive.google.com/file/d/0B8JUL90DXgdiMTZ...
Re: Random thoughts for the day
by ZSHO | January 17, 2019, 05:16:56 PM
JAN 14, 2019 | FORD MOTOR COMPANY PRESS RELEASEALL-NEW FORD EXPLORER G...
MOVED: Looking for used Cat-Back for A 2014 SHO
by ZSHO | January 17, 2019, 04:25:11 PM
This topic has been moved to Parts for Sale or Wanted.https://www.ecob...
Re: Splash blending e85 to 93
by FiveLeeter918 | January 17, 2019, 01:44:28 PM
Thanks to everyone! To prevent any fuel related issues god forbid I ru...
Re: Livernois Upgrades
by Livernois Motorsports | January 17, 2019, 07:45:34 AM
I just wanted to share my recent experience with Livernois and my 2018...
MOVED: Livernois Upgrades
by SHOdded | January 16, 2019, 08:09:34 PM
This topic has been moved to Livernois Motorsports and Engineering.htt...
Re: Something different?
by SHOdded | January 16, 2019, 04:29:39 PM
LOL, yes, my reference was the first gen V's, since people buy th...
Back to top
