Turbo Smart wastegate actuator for SHO??
Started by ddlopes, September 27, 2015, 10:35:59 AM
ddlopes
I came across this article where they installed a turbo smart wastegate actuator on the ecoboost mustang. Very impressive mid range hp and trq improvement. Anyone out there install this wastegate actuator?? I know they install them on the upgraded turbos from ecopowerparts.
http://www.stangtv.com/?p=457682
2013 SHO P/P mods: EcoPower Parts dual CAI, 3 bar, PPE catted down pipe, SCT X4, 170 degree thermostat, SNOW PERFORMANCE methanol stage 3 with ProMeth staineless steel braided lines, AeroForce gauges, Hot pipes, custom boost activated cutout xpipe, tial bov, Tial Wastegate mod, GH intercooler, MSD coils, AFE throttle spacer, UPR catch can, Rovos Durban wheels, AJP tuned to 389hp and 503trq on mustang dyno
Interesting article and product... Does it come in a direct bolton version for the SHO?
AJP turbo
Ill try and post more later...i would not put anything like that on this car....its no surprise their advance trac was giving the car issues during the testing....they seemed to think if they reflash to reset the adaptives it would get better ...might get worse...people dont really know what all the adaptives do and the tables that go along with it...but they all act like they know when they say things like reset the adaptive strategy and it can help
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
ddlopes
I'm going to call Turbo Smart tomorrow... I hope it's a bolt on like the mustang ecoboost. I'd be extremely happy with the additional mid range power that ecoboost mustang got after the installation. Like i mentioned previously their using them on the upgraded turbos so my guess is their available for our cars.
AJP turbo
This is about as good of an idea as putting a manual boost controller on these cars..u can adjust the wastegate preload in the tune with the sho
Stock is set to 6.5psi...i have mine at 12 so the wastegate doesnt crack early which helps turbo response.
This mod will most likely lead to throttle closures to control boost because boost levels will not be what the ecu is expecting to see.
U want more midrange power?..dial in more boost with the tune and do it the right way...due to complex and complete wastegate dynamics of the ecoboost boost control system this mod will skew the tables...who knows what pressure spring is in the turbosmart wastegate...its most likely different
All the tables in the tune are set up for whats in the oem wastegate..if u change that then everything will be off....
I doubt ur tuner would spend much time redefining some of those tables...some of the tables for wastegate duty cycle are based on desired exhaust flow through the turbine
Ford spent alot of time populating the tables for what wastegate duty cycle will yield certain boost at all load and exhaust flow
The boost control in the sho is like the cars that are mass airflow tuned in the sense that u cant just throw an intake on and go ...seems innocent enough just to change an intake tube but the way the maf reads in a tube of different geometry skews the airflow readings
Change a component of the boost control system in the ecoboost and the computer wont understand why the expected outcome is not whats expected...
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
ddlopes
Doesn't look like they offer one for the 2013-present SHO due to their electronically controlled. They do how ever offer a Bov that's run electronically. Theirs a lot of 2011-2012 F150's having good results with the turbo smart wastegate actuator.
AJP turbo
All ecoboost engines have electronic boost control including the ecoboost mustang so not offering it to the sho for that reason is suspect....so i wouldnt put that wastegate actuator on any of them...
And i dont see a reason to upgrade the bov unless you had trouble maintaining higher than stock boost pressures like some of the lancer guys ...
There is alot of ecoboost f150 having good results without an aftermarket actuator...im sorry but thats just a waste of money
Anyone that would want to put that on their car obviously has never seen the tables for the turbo in the tune lol
Through programming we can have the benefit of multiple springs in the wastegate diaphragm...its a pretty sophiticated boost control we have in these ecoboosts
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
ddlopes
AJP turbo
Quote from: ddlopes on September 27, 2015, 09:30:07 PM
It's ok to disagree.
Ok for me to disagree, i know
Ok for you to disagree with me?...absolutely not
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
The vacuum actauated wastegate system is a mechanical-pneumatic boost controller,boost pressure is limited mechanically via a diaphram and spring,boost pressure can be increased within a limited range by controlling a wastegate pneumatic solenoid,the wastegate pneumatic solenoid valve will be discussed on a  later session which is very more appealing and plays a larger role in the procedure.  Z
ddlopes
metroplex
Quote from: AJP turbo on September 27, 2015, 02:14:31 PM
I'm not sure about SCT, but using HPTuners I found the stock SHO setting for Wastegate Spring Preload was 3.19 psi
The F-150's with the 3.5L EcoBoost were set to 4.65 psi stock.
The 2015-up Mustang 2.3L EcoBoost was 9.29 psi, and the Focus RS was set to 9.58 psi
Is there any merit to increasing this scalar setting in the tune? And if so, how much should go we up?
Previously: 2014 SHO
12.4 @ 110.9 mph
Current: 2017 Fusion Sport
2013blksho
AJP turbo.  Are you doing any tuning for anyone. I have not tuned my sho yet but I like that you dig a little deeper than most.  Let me know if you are and what I need to do to get that to happen.  Thanks!
TimmyATL
I installed the Turbosmart 7lb wastegate actuators on my 13 PP SHO. I have had no problem with them. The thing I noticed is that part throttle drivability is better. It boosts much quicker when tipping in at part throttle. And my tuner said nothing to me when I had it dyno tuned a couple weeks ago and it made 437 torque with stock turbos
13 SHO PP, Airaid intake, 170 T-stat, 3bar map sensor, Ecopower Parts hot side pipes, Turbosmart 7lb wastegate actuators, Stainless Works catted downpipes, Corsa cat back exhaust with Loudvalves exhaust dumps, Alky Control Meth Injection, LMS Dyno Meth tune. TSW Nurburgring  with NItto NTO5
ddlopes
Quote from: TimmyATL on November 01, 2016, 03:30:03 PM
Was it a difficult install? Did you have to remove the turbos to install them? Once they were installed did they needed to be adjusted? I'm still interested in this mod.
