The vacuum actauated wastegate system is a mechanical-pneumatic boost controller,boost pressure is limited mechanically via a diaphram and spring,boost pressure can be increased within a limited range by controlling a wastegate pneumatic solenoid,the wastegate pneumatic solenoid valve will be discussed on a later session which is very more appealing and plays a larger role in the procedure. Z
