Started by Expygator, September 25, 2015, 03:12:23 PM
Quote from: Expygator on September 25, 2015, 03:12:23 PMWill a tuned car ( stage 4 ) with 3 bar, t-stat and plugs pass emissions tests?
Quote from: Courier6 on September 25, 2015, 05:39:32 PMQuote from: Expygator on September 25, 2015, 03:12:23 PMWill a tuned car ( stage 4 ) with 3 bar, t-stat and plugs pass emissions tests?I doubt it, I have to put the 2 bar in and return to stock, then do the readiness for inspection drive cycle every year, just went through it this month.
Quote from: ajpturbo on September 25, 2015, 06:07:16 PMQuote from: Courier6 on September 25, 2015, 05:39:32 PMQuote from: Expygator on September 25, 2015, 03:12:23 PMWill a tuned car ( stage 4 ) with 3 bar, t-stat and plugs pass emissions tests?I doubt it, I have to put the 2 bar in and return to stock, then do the readiness for inspection drive cycle every year, just went through it this month.When you say "Return to stock" - Are you removing the PPE DP's too, or just stock tune & 2 bar MAP? Do they have a visual inspection for cats in TN?Also - How stringent is TN regarding window tint? - I have 20% all around (27% is legal here, and I see many, many people running 20% with no hassles). Considering a potential move to TN...
Quote from: MileHighV on October 08, 2015, 01:42:16 PMQuote from: ajpturbo on September 25, 2015, 06:07:16 PMQuote from: Courier6 on September 25, 2015, 05:39:32 PMQuote from: Expygator on September 25, 2015, 03:12:23 PMWill a tuned car ( stage 4 ) with 3 bar, t-stat and plugs pass emissions tests?I doubt it, I have to put the 2 bar in and return to stock, then do the readiness for inspection drive cycle every year, just went through it this month.When you say "Return to stock" - Are you removing the PPE DP's too, or just stock tune & 2 bar MAP? Do they have a visual inspection for cats in TN?Also - How stringent is TN regarding window tint? - I have 20% all around (27% is legal here, and I see many, many people running 20% with no hassles). Considering a potential move to TN...I just have to put the 2 bar back in and return to tune to stock in order to pass. Done it three times now.Tint darkness for sedans:Windshield: Non-reflective tint is allowed above the manufacturer's AS-1 line.Front Side windows: Must allow more than 35% of light in.Back Side windows: Must allow more than 35% of light in.Rear Window: Must allow more than 35% of light in.
Quote from: MileHighV on October 08, 2015, 06:09:16 PMIs the TN inspection strict about the 35%, or will they let you slide?Here in CO, 20% on the fronts is common (7% darker than legal), and cops don't seem to care, and neither do the inspection stations (semi-annual).Thanks!
