Ecoboost Performance
General Discussion
Engine and Transmission changes
Started by shaneirish, September 22, 2015, 05:03:10 PM
shaneirish
Forum Supporter!
Jr. Member
Gunner
If you came across a used 2010 SHO engine and transmission with about 60,000 miles on them what would you do(without breaking the bank) to beef them up a bit..especially if you run with a LMS tune?
2010 SHO 20" Wheels, LMS 4X tune, AirRaid CAI, 3-Bar MAP, 160 Thermostat. TSB's and Failures TSB-11-12-10 - 6F50/6F55 TRANSMISSION. TSB 11-11-09 - INTERMITTENT STEERING DRIFT/PULL. All four wheel bearings replaced winter 2014-2015 (all failed at different times and within four weeks of each other, PTU Failure at 54,000 miles. Climate heat issue fixed, halfshaft issue. Right front strut bearing plate failure at 79,000. TSB installed the thrust washer over the halfshaft.
SCT dealer and custom calibrator 3.5 ecoboost specialist
Vendor
Log Warlock
Re: Engine and Transmission changes
September 22, 2015, 05:48:35 PM
U can't do anything to the engine and trans without breaking the bank
General Discussion
