Tuning Impressions, Opinions and a few Questions
Started by JDW1, September 03, 2015, 01:18:16 PM
Skeezixzx9r
Quote from: JDW1 on September 03, 2015, 02:47:14 PM
Quote from: FoMoCoSHO on September 03, 2015, 02:41:15 PM
Knock and waste gate duty cycle are clearly in the configurable options.
When looking on the device itself, i did not see either.  Are you saying i can plug it to the PC, in live link then configure?
If you are in the car and watching the datalog guage readout, you can use the arrow keys to highlight the current gauges, mine uses a red outline.  Hit the center button and it will bring up a list of parameters that can be viewed.  Select the one you want and it will replace the highlighted gauge.  I have knock displayed on mine all the time.
Thanks skeez, forgot about that. I only use mine to flash and data log with a laptop cause I don't want that ugly piece of plastic crap on my dash any longer than I have to....
JDW1
Quote from: Skeezixzx9r on September 04, 2015, 12:13:08 AM
Don't you have to have the laptop and the device all hooked up to do all that though.  I just wanted the device to display KR and WGD so i could just live monitor.  I don't want to have to lug my laptop around every time, do a full log WOT and mess with all that.  I just want to hold the SCT, look at a few parameters live while driving.
Also, 1st to 2nd shift seems awfully rough, IIRC that could be tune related?
13 SHO, Unleashed 3bar Tune, 1 step cooler NGK's, MDesign CAI, 170 t-stat and meth.
You can have shift pressures lowered to the 180-90ish range for a smoother 1-2 shift.
Quote from: JDW1 on September 04, 2015, 12:04:52 PM
Yes, have torrie dial it back a bit. I had that issue on the 2013, 2015 is perfect.
And no what he is talking about is on the scanner. Use the arrow keys to move over a gauge and hit the red button. It will open a scrolling menu for you to choose a new gauge in that spot.
JDW1
Hey guys, when configuring a data log file, please tell me you can just add boost_PSI like whats just on the device?  I have created two now and cant get plain ole boost in PSI to be a data point.  I'm feeling like a tard and frustrated.
Are you having a hard time finding boost or getting it to display in psi?
Scroll over to the units and most have a drop down box to change it.
Oddly rear fuel pressure doesn't which drives me nuts
JDW1
Quote from: FoMoCoSHO on September 10, 2015, 12:42:28 PM
I took the MAP from KPA to PSI and it's no where near the same as just the pre-loaded (Ford 08-newer)configurations "boost_PSI".  I looked at the Config Torrie sent and even created my own to see them all and out of the 2 i thought to change from KPA to PSI, neither give me a good reading, like the other.
Quote from: JDW1 on September 10, 2015, 01:06:25 PM
Click list at the top and in the search bar at the right and enter boost
There is a boost pressure at the bottom in miscellaneous, cant change the unit though
AJP turbo
#25
Fomo, get rid of rear fuel pressure..not sure what that is...I used to log that until I found the obd pid "fuel rail pressure"..u have to make available all the pid's..u can log it in psi....I think the rear pressure is at the high pressure pump but before rail...it's too high to be the low side from the tank.
Jdw1 u are probably displaying psi in absolute...in the drop down see if there is "/psi that might be what u want..I usually log kpa for boost...below 102 is vacuum....200 is about 15ish
I'm talking for live link gen 2....I always use a laptop...pain but better..unless u can load a confit to the device..I've never done that...I love the graphs and features of the logging software by sct
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
There is also tip prs boost.
IDK if that shows ambient pressure combined with boost, I think that's what Torrie uses but it can also be selected in PSI.
Quote from: ajpturbo on September 10, 2015, 01:34:10 PM
I think it is like Torque where there is 2....
Rear is at the pump, rail is actually rail, hence the higher pressure than the pump allows.
My understanding is the pump is 2150 max not to exceed 3 on the rail.
2750 on the rail makes me horny...
JDW listen to AJP, he's much more advanced than I....
JDW1
#29
I can see if I selected absolute and if there is another drop down but this is terribly annoying.  I hate logging with a laptop in the car, mouse hovering over the start/stop log buttons while approaching 100 mph.  I just want to log from the device, one hand it with the button and be done, thats what I did with my AP and it stored multiple logs on the device. The parameter should be just like the factory setting, boost in PSI, why is that so dang hard..
