Fastest sho with unleashed tune
Started by f8tlSHO, August 17, 2015, 01:45:29 PM
Helps to have good DA at the track :)  Cecil County is famous for that!
Rocketship there, f8tlSHO, great results!  Where do you normally fuel up from?  Shell, Exxon, ...?
f8tlSHO
Quote from: AJP turbo on April 09, 2016, 12:59:11 AM
f8tlsho how mature was the tune when you ran? How long was the tune on the car when you ran? No downpipes either?
That is a solid time I think for that boost..Makes me optimistic of times I may run. Your desired TIP was about 203kpa. So you were targeting around 15psi throughout the rev range and gears through the run. That's exactly what I've been running while I've been working on some things....I thought I would have to run more than that to run that kind of time.....You didn't have any knock...Your boost spikes on upshifts but that's an unavoidable condition if the throttle stays open, which it did....The stock tune will regulate that with the throttle. Your boost falls off a bit near redline but it's not bad at all, I've seen worse. You have to tell it when and where to add wastegate duty cycle.
Anyway nice run and thanks for the datalog...You basically log the same stuff I do...I've been wanting to see a nice time with no meth and data with items similar to what I would log so that fit the bill near perfect
This tune has been on the car since Sunday. Only 1 revision on it. No down pipes, just e20, 3 bar, and k&n drop in.
2013 Non PP Unleashed 93 E20 3 Bar Tune, K&N drop in 12.491 @ 110.96 120's IAT
Now tuned by ajp...looking to go faster
E30 tune on14psi full weight including 2 child seats,race like a real street car.
12.433 @110.8 140's IAT; Mustang Dyno 332hp / 386tq
f8tlSHO
f8tlSHO
Quote from: SHOdded on April 09, 2016, 04:49:35 AM
Normally bjs wholesale club, but this was from sheetz convenience store.
f8tlSHO
Da was really low, low hundreds to negative hundreds depending on time
Sent from my iPhone
Pretty good
Quote from: f8tlSHO on April 09, 2016, 07:21:38 AM
:thumb:  once again, well done!
Quote from: f8tlSHO on April 09, 2016, 07:27:18 AM
Sent from my iPhone
Congrats on your new PB.  Z :thumb:
@ f8tlSHO
Dd you adjust your tire pressures?
f8tlSHO
BMC10SEC50
12.41@111.....no meth, no E85, no race gas, just a badass 93 Torrie tune!
-2013 SHO PP with Unleashed 3 bar tune, CAI, plugs, thermostat, off road downpipes and Corsa exhaust. Best time to date is 12.26@112.47mph.
-1990 5.0 LX(original owner) 349 BOSS block, Twisted Wedge heads, Holley intake, Vortech Si trim. Made 636hp to the wheels with a street tune.
ElvenSho
Quote from: BMC10SEC50 on April 20, 2016, 11:25:16 AM
Hopefully this new tune he sent me is the same as yours, i will know this saturday haha.
2011 Red Taurus SHO- H&R springs, plugs, t-stat, 3bar, LMS dps, tuned by Torrie
BMC10SEC50
He wouldn't send you my tune. This is the difference between data logging and building a generic tune on a dyno. All cars are different and all areas have different weather so my tune is my "custom" tune built from the logs. Your tune will be custom to your car in your weather conditions. This is one reason I left the other guy to go with Torrie.
ElvenSho
Quote from: BMC10SEC50 on May 04, 2016, 10:33:23 AM
Yup I know what I meant is how aggressive it is. I ran a 12.6@109 so close enough :)
BMC10SEC50
Good pass- how many times has he tweaked your tune? Are you maxed out?
ElvenSho
Quote from: BMC10SEC50 on May 04, 2016, 03:18:36 PM
17 revisions, yes I am maxed out. At this point I am trying to add some e85 (3 gallons to a full tank) and need to send him a log this weekend.
