Again... Thanks for the great replies... Folks here seem to be way more informed on this type of issue than the truck-specific forums.
QuoteHow to reset your KAM...
Can anyone verify that a fresh SCT 'return to stock and load custom tune' resets the KAM? If not, I need to modify my test procedure.
Quote...what is your KR reading?
My knock reading looked extremely screwy... No positive knock and massive negative knock, but still way retarded timing. I'll post another screen capture.
Quote.I am also leaning toward the truck is trying to protect its self.
Sure seems like it, but it doesn't seem like it should have to... Why TF can't it just drop a gear without me putting my foot into it?? It would make much more sense then chopping boost and timing. Something like this:
IF (bad s*** is detected) AND (rpm's are really low) AND (current gear is 4,5,6) THEN (downshift quickly and resample)
QuoteI am also assuming that the truck is fine at WOT from a stand still? Is it ok when you stand on it at say 55mph?
Yup, works great tuned and stock in both of those scenarios...
also...
QuoteI was curious to see your modification list.
Pretty much stock mechanically.. Slightly oversize tires (285/70-17, 32.08" diameter), AEM dry-flow air filter, boost gauge.
