2014 Taurus SHO - RASP From Hell Part 2!
Started by 14SHOCAR, June 23, 2015, 04:05:28 PM
14SHOCAR
Whats crackin' people. I finally got my Rasp from hell part 2 video up with my fix + dyno. I have two more vids on their way! I hope you enjoy them!
http://youtu.be/xBmdO_t_Le8
14 Taurus SHO (Sold)
PokerMunkee
Nice work.  You got a great voice for this kind of stuff.
2011 F-250 6.2 CCSB FX4
pejohnson
Very nice. Thanks for posting.
13 Platinum White, PP, 402A, Moonroof, Multi-contour seats, and Navigation.  MODS - LMS 93 octane 3bar tune, 160 LMS thermostat, Airaid CAI, 15% tint, interior LED upgrade, LED puddle lights, Nurburgring 20" Gloss Black Powercoated Rims, H&R springs, Corsa catback exhaust, LMS catted downpipes
Best time 1/4 mile 12.588 sec @ 109.44 mph
Haha! He does. You should do some promotional voice over work or something. I think your voice is salable.
bamsho
Very cool video.  That's why I didn't spend big money on aftermarket exhaust.  I just have a modded factory setup with LME DP's and Dynomax mufflers.  Sounds nice, no rasp.
BigPelo
So you had rasp with stainless works catless downpipe and corsa exhaust. Now you run stock downpipe and resonated xpipe on the corsa? Sorry english is not my first language...
Week-end family transporter: 2013 SHO tuxedo black, performance package, unleashed custom 94 octane tune, K&N Typhoon intake, 170F thermostat, 3 bar MAP sensor, SP534 spark plugs, 5000K HID Morimoto mini D2S projectors retrofit, tinted windows, Full LED lighting in and out, Eibach springs
Daily beater: 2002 WRX wagon swap JDM STi v7 20G'd
J-Will
you're upset with a 21hp gain from just a catback?
3-bar
SP-542 plugs w/ GH gap
14SHOCAR
Quote from: J-Will on June 25, 2015, 09:00:11 AM
I have another video coming up that will explain it in detail, and yes, I am not happy with the 21HP gain. The Livernois tune does a lot for the vehicle outside of adjusting the boost levels (transmission line pressures, shift points, etc). However, I spent probably close to 3k-4k in mods on the car and I only got a net of 40awhp/30awtq.
That's a little lack luster IMHO. Don't get my wrong, my car is a BEAST and I've been able to smoke vehicles with almost 3/4 more power than mine. The cost per HP would have been better put towards something else.
14SHOCAR
Quote from: BigPelo on June 24, 2015, 07:49:35 PM
I had the stainless works catless downpipes and corsa exhaust. I removed the stainless works catless downpipes and ONLY have the Corsa Exhaust. The Corsa Exhaust as an X Pipe built into it already.
ShoBoat
Quote from: 14SHOCAR on June 25, 2015, 10:44:52 AM
Your net increase includes all mods with the 93 tune?
2012 Pearl White CTS-V Stock
I guess even dyno;s can be off by a little if not done at a reputable facility,but from my understanding a gain of 21hp from a cat back exhaust sounds a bit excessive,usually that sounds about right if you were refering to DP. LOL something isnt adding up right. Z
J-Will
I'm anxiously awaiting the second video.  You are directly influencing my decisions so I do appreciate the foundational work you're putting in
your overall gains do seem low, however your gains from 'only' the cat back seems very high, especially when referring to gains seen at the wheel!
3-bar
14SHOCAR
For any of you that have been to the dyno with the SHO, these cars with any sort of tune are extremely difficult to lock into a gear for the dyno run. They like to downshift like crazy. Unless you electronically lock it into a gear, there isn't an easy way to keep it in gear. There could be a couple of reasons for what I gained.
#1 It downshifted and spiked the numbers (not likely). The dyno is reading that power band across the board. If it was a spike you'd see the numbers go up then drop down.
#2 My runs after the Livernois tune were low. I'm leaning more towards this. I have a video coming up (and I dont' have the numbers on this laptop) that will show the progression in the gains.
I hope this helps clarify things.
That's why we like time slips...dyno #'s are, well, just #'s...cool video though, great job.
Rich
J-Will
Quote from: SHOnUup on June 26, 2015, 10:28:02 AM
Rich
time slips are numbers too
3-bar
