Ecoboost Performance
Troubleshooting, Maintenance, TSB Articles
Troubleshooting
Transmission slipping? Upgrade? Ideas needed...
Started by Grimster, April 24, 2014, 06:42:18 PM
Gray Brick
Sr. Member
Gray Brick
Re: Transmission slipping? Upgrade? Ideas needed...
#15
June 15, 2015, 01:27:37 PM
I had the same problem... I was running too much w/m. It was quenching.
I went to a smaller nozzle and it went away and picked up tons of HP as well.
2013 Ecoboost Ford Flex
14SHOCAR
Sr. Member
14SHOCAR
#16
June 15, 2015, 02:00:34 PM
I had the same problem and the issue had to do with the vacuum lines. Check out my video.
https://www.youtube.com/watch?v=vrhBu5XtafU
14 Taurus SHO (Sold)
Troubleshooting
