U.S. 131 Motorsports Park 5/22/15
Started by donky4444, May 23, 2015, 06:26:41 PM
donky4444
Me vs a stock 2015 Challenger SRT 8. His first run of the night was a 12.18 but he couldn't repeat that. I ran a 12.61 to his 12.49 but I got him at the tree.
https://youtu.be/b0eEElxiFPg
Me vs Camaro, not sure what he had done to it though. I got him at the tree and jumped out with a good lead but he reeled me back in. He ran an 11.8 to my 12.61.
https://youtu.be/u8D4uHEAFTE
snaf2u
Nice job on the tree! Good consistent runs. Well done. Keep it up!!
2013 SHO red w/PP. Stock with Livernois stage 4 tune using the 93 octane new revision tune. Best of 12.79 @ 106 on 5-01-15 at US131 dragway, Martin, Michigan.
donky4444
Quote from: snaf2u on May 25, 2015, 07:49:21 PM
Thanks. We missed having you there. We will have to make another trip out soon. I think the wife is hooked after her first trip so now she wants to go without our boy and stay later. I want to get her to ride with me for a run so she really gets the feel for it. I think I may be able to get her to try driving eventually.
Nice runs Don. Thanks for the video share, adds a little depth.
You running some corn still?
Rich
donky4444
Quote from: SHOnUup on May 26, 2015, 07:27:59 AM
Rich
Yep.  Still 13 gallons of 93 to 1 gallon of E85.
Quote from: donky4444 on May 26, 2015, 09:49:14 AM
Rich
I've been adding 4 ounces of MMO (marvel mystery oil) to the tank about every 3rd or 4th fill up. Really helps quiet the loud HPFP system.
Rich
southtxSHO
2011 SHO non PP
LMS 4 +tune
LMS Cai
LMS catted downpipes
12.89@ 105 MPH best time @ Edinburg Raceway
southtxSHO
Rich
Sorry for the dumb  question lol but when you mix the E85 with 93 octane . Does it matter what you put first in the take either E85 or 93 octane . Thanks
2011 SHO non PP
LMS 4 +tune
LMS Cai
Quote from: southtxSHO on May 27, 2015, 12:15:57 AM
Rich
If you're in the miles to empty zone, less than 3 gallons in tank, I'd recommend putting in the 93 first. If not you can risk sucking in too much of the spiked punch bowl. For optimal mixing (just in my head) it's nice to put the corn in first.
Side note: spike the punch bowl a bit more this last time....1.5 gallons of corn, car likes it....back to zero knock on wot pulls
Rich
southtxSHO
Quote from: SHOnUup on May 27, 2015, 06:34:38 AM
Rich
Rich
Thanks for the info Rich... going to put some corn today and see if I can make it to the track .
2011 SHO non PP
LMS 4 +tune
LMS Cai
CL Donttry
Why does mixing e85 help you get better times? I'm totally confused by this I run the LMS 4 plus tune and I don't get it a little lesson please. I've never raced at a track going to take my SHO for first time are you guys manually shifting or you letting the tunes do your work?
Dbad1
2012 Taurus SHO modified, K&N CAI,3bar,LMS thermostat, NGK gapped plugs, Unleased DP, LMS Thunderstorm Cat back,LMS 4 plus tune, EBC slotted cross drilled rotors, MGP caliper covers, SHO hood graphics, Chrome grill inserts, Continential Purecontact tires
2010 BMW 528 Xdrive
2015 GMC Sierra SLE
ecoboostsho
Adding E-85 effectively raises the overall Octane of your fuel which suppresses knock and allows more timing to be run.  The car will try to add timing and when it can it will make your car faster - up to a point though.  E-85 has a lower energy content (I think that is the correct term) so you need to use more of it...the car/fuel pump will compensate but after a certain point it can't keep up.  In other words you can only add a little and still be safe on the stock fuel system with a tune.  You can run higher concentrations with the stock tune as I believe as there is more "headroom" although Ford doesn't want you to.
Rich
I would say it depends how far you are from stations...mine are fairly close so I put the corn in first so it mixes better.
No issues and the trims just start to move as I get to station 2. Usually when I do this I have around 2 gallons of the mix remaining and then add 3 gal of corn. So yeah, a pretty high blend for a couple of minutes and no issues.
I dont think either is wrong but if you don't mix it well when you fill it, the trims take a little longer to settle down.
firewater88
Nice runs. Good trees.
Was going to take my SHO there back in the day, before they re did the whole complex and track, but never did.
I don't live far from there, about 40 min north or so...
2011 Flex Titanium EB
Retired- 1992 SHO
donky4444
Quote from: firewater88 on May 30, 2015, 06:02:40 PM
Bring the brick out one night. I may go back 6/5 if the weather is good.
