Pictures of a lowered SHO?
Started by Fronzizzle, May 14, 2015, 09:24:29 PM
Fronzizzle
I have a silver 2014 SHO and I'm thinking about getting the H & R springs to lower it.  I've read a bunch of the posts regarding this, but I'm having a hard time picturing my car lowered.  Can someone post some photos of a lowered SHO?  How is the tire clearance?  Any issues?
Stuntz
Unleashed Tuned, Airaid, 3 bar, 170 t-stat, H&R Springs
Stuntz
Love that stance stuntz.
What size wheel spacers are you using ?
2010 RCM non PP
K&N panel filter
sp534 @ 30
unleashed 93 performance+boost 3bar
more to come.....
Stuntz
Stuntz
Wilson
Dropped on 22's.  Don't worry about clearance at all if you're on stock wheels/tires.  I'm on 265/35/22s - about 3/4" taller tire than the stock setup - and I have no issues whatsoever.
2013 SHO (non-PP) Ruby Red Tintcoat
Leading Edge Tuning 93 Tune | 3 Bar MAP | 170* Thermostat | Airaid Intake | PPE 2.5" Downpipes | Snow Stage 2 Meth Kit | H&R Lowering Springs | 22" Falken RT-7M wheels | 265/35/22 Falken Ziex TZ05 tires
BigPelo
Quote from: Stuntz on May 15, 2015, 08:30:59 AM
25mm rear and 10 front
Which studs are you using? Size or links please. Thanks!
Quote from: Wilson on May 15, 2015, 08:43:29 AM
I love your wheel setup! :thumbup:
Week-end family transporter: 2013 SHO tuxedo black, performance package, unleashed custom 94 octane tune, K&N Typhoon intake, 170F thermostat, 3 bar MAP sensor, SP534 spark plugs, 5000K HID Morimoto mini D2S projectors retrofit, tinted windows, Full LED lighting in and out, Eibach springs
Daily beater: 2002 WRX wagon swap JDM STi v7 20G'd
sunwolf
It looks alot better lowered but I need to drive in the snow.
2014 Taurus SHO Black Performance Pack LMS tune 3bar tstat downpipes
2008 BMW M6 Convertible SMG
2008 F-150 XLT 4x4 5.4L
2011 F-150 Ecoboost Crew Cab 4x4
2012 Lincoln Navigator L 4x4
Quote from: sunwolf on May 15, 2015, 09:52:00 AM
If you are low enough you can moonlight as a snowplow.....
14SHOCAR
Quote from: FoMoCoSHO on May 15, 2015, 09:56:57 AM
LMFAO
14 Taurus SHO (Sold)
Stuntz
The rear spacers are the hubcentric bolt on kind so no extra studs needed. In the front I used arp extended studs.
BigPelo
Quote from: Stuntz on May 15, 2015, 11:08:32 AM
Something like these?
Mr. Gasket#720-4311
Competition Wheel Studs
Chrysler, Ford, and Most Applications with 1/2" Studs
1/2''-20 x 2-7/8''
.665'' Knurl Diameter
.641'' Drill Hole
http://www.jegs.com/i/Mr-Gasket/720/4311/10002/-1
Stuntz
No, you need 100-7722 for them to fit in the hubs.
