Archoil
Started by jtoddk98, May 10, 2015, 10:16:31 PM
jtoddk98
#15
Quote from: glock-coma on May 12, 2015, 09:50:36 AM
I signed up for the free sample from archoil to try it out. Just need to pay 4.95 shipping.
The sample treats 80 gallons
Here's the link if anyone is interested. It's for the fuel treatment only.
http://archoil.powerstrokehelp.com
yup, that's what I did, I got hooked, and bought the $50 thing of it. You guys should watch his videos, he's hilarious. The proceeds from his archoil sales goes to a program he runs to rehabilitate veterans and training them to become diesel techs
One thing I forgot to note about the fuel additive, once I started using it, my tailpipes have stayed clean/or a helluva lot cleaner then they were.
2011 Taurus SHO Performance Package. EBC Stage 4 Brakes. Blacked out chrome. #130 of 602 in Ingot Silver
jtoddk98
Quote from: wasinger3000 on May 11, 2015, 11:50:12 AM
Yeah I bought the 8oz fuel and the 16oz oil.
Did some research into the fuel additive and found out GE uses it in their diesel locomotive engines as well as large cargo ship engines with great results.
any results yet?
wasinger3000
Quote from: jtoddk98 on May 17, 2015, 11:31:00 PM
any results yet?
Just got the stuff Friday but I'm only running the fuel treatment. I'm going to put the oil additive in when I change oil next time.
So far it seems like the "normal" noise the injectors made have become more subdued.
13' GTCS, will be missed.
Quote from: sunwolf on May 11, 2015, 02:49:19 PM
Quote from: FoMoCoSHO on May 11, 2015, 02:38:05 PM
I would also like to know how it lowers ethanol content.
Cause that's not necessarily a good thing in DI cars anyway....
I wonder if the ethanol absorbs it like H2O????
The reason I'm asking is because it can't. The methanol does not absorb the water, it allows the water to become soluble in the gas which allows it to be removed when it goes through the engine with the gas. This stuff shouldn't be able to make ethanol disappear, it just puts it somewhere else.
Methanol is hygroscopic, it does absorb the water.
http://web.eng.ucsd.edu/mae/groups/combustion/NASA/water.html
Data comes from here
http://web.eng.ucsd.edu/mae/groups/combustion/NASA/micro-g.html#Theoretical%20Study
Most likely a bad test though...
I did find this however....
"Certain hygroscopic substances, not only absorb moisture from the air, but also dissolve themselves in that moisture, undergoing a change of state. Such substances are called deliquescent substances. The process is called Deliquescence."
http://chem-guide.blogspot.com/2010/04/hygroscopic.html
I wonder if that applies to hygroscopic substances in a solution as well.
Burning behaviors of collision-merged water/diesel, methanol/diesel, and water + methanol/diesel droplets
https://www.deepdyve.com/lp/elsevier/burning-behaviors-of-collision-merged-water-diesel-methanol-diesel-and-q0wCqPkF4p
11 Things You Need To Know About Water/Methanol Injection
http://www.dieseltechmag.com/2010/04/11-things-you-need-to
sunwolf
Quote from: FoMoCoSHO on May 18, 2015, 01:50:06 AM
Yes if you leave the cap off of a bottle of 100% methanol it will take in water from the air. If you add a bottle of methanol to a gas tank with some ethanol or water in it there is still the same amount of ethanol or water in the tank. The methanol is not absorbing anything it is just making it mix better.
2014 Taurus SHO Black Performance Pack LMS tune 3bar tstat downpipes
2008 BMW M6 Convertible SMG
2008 F-150 XLT 4x4 5.4L
2011 F-150 Ecoboost Crew Cab 4x4
2012 Lincoln Navigator L 4x4
wasinger3000
Quote from: sunwolf on May 18, 2015, 12:24:48 PM
http://en.m.wikipedia.org/wiki/Hygroscopy
"Hygroscopy is the ability of a substance to attract and hold water molecules from the surrounding environment. This is achieved through either absorption or adsorption with the absorbing or adsorbing substance becoming physically changed somewhat. This could be by an increase in volume, boiling point, viscosity or other physical characteristic of the substance, as water molecules can become suspended between the substance's molecules in the process."
In short, methanol will suspend moisture through a physical change.
sunwolf
Quote from: wasinger3000 on May 18, 2015, 01:02:58 PM
Yes the moisture is suspended but it is still there. If there are 2 ounces of water in your gas tank there are still 2 ounces when the methanol is added it is just more dispersed. Not trying to start a fight this stuff is just part of my daily life being a chemist. Also hygroscopy refers to the ability of a solid or liquid to absorb water vapor from air. The term does not directly apply for mixing liquid water with liquid methanol.
wasinger3000
Quote from: sunwolf on May 18, 2015, 01:30:39 PM
Lol not trying to argue, and I understand the water is not removed. I was just stating it is absorbed.
jtoddk98
Quote from: wasinger3000 on May 18, 2015, 02:50:16 PM
have you used the oil stuff yet?
wasinger3000
Quote from: jtoddk98 on June 21, 2015, 04:26:36 PM
Just put it in my car Wednesday. To early to make any serious claims.
So as I look at diagrams of of meth and water in a solution, it seems the term "adsorbed" would apply better. My non science brain boils it down to basically, it just grabs the water and carries it to the goalpost.(injector)
wasinger3000
Quote from: FoMoCoSHO on June 21, 2015, 05:39:50 PM
Yeah that's all it is doing. It's just suspending the water. I've been mixing water and meth in a Glas jar at different % and temperature to see how it reacts.
Since I've switched to 100% injection I've noticed less of a intake temperature drop than I had with 90%m 10%w.
f8tlSHO
I ordered my archoil sample, should be here in a day or 2. See if it does anything
Sent from my iPhone
f8tlSHO
I didn't notice a difference in power or mpg, did not check temps
Sent from my iPhone
