Ecoboost Performance
Troubleshooting, Maintenance, TSB Articles
Maintenance, Oil, and Fluids
BG Products....Fuel and oil additives
Started by Scott13SHO, April 28, 2015, 12:46:31 PM
Scott13SHO
Sr. Member
Ecobooster
So what's the word on the street with using BG Products in the 3.5L Ecoboost? I was looking at their testing they did with at 2011 and it seems like it does a good job with cleaning the deposits off the engine. Looking at possibly using their MOA 110 Engine Oil Supplement and BG44K fuel additive...
https://www.bgprod.com/bgfueltest/
Ruby Red 2013 Ford Taurus SHO with Performance Package,Airaid CAI, MGP Red Caliper covers, LMS 93 Tune, Custom A-pillar Gauge pod with Aeroforce Interceptor Gauges, LED Interior and Exterior lights
booooost
Re: BG Products....Fuel and oil additives
April 28, 2015, 01:13:10 PM
Only issue I see with moa is its basically a additive pack in a can. I would have to find the voa from bitog but it seemed to have high zpds. And that would be good but too much phosphorous I think kills cats and o2 sensors. Other than that the products of there s that I have used have all worked . so maybe use only part of a can instead of the full thing. The 44k is great stuff.
CL Donttry
Fast_N_Furious
Jr. Member
Ecobooster
May 25, 2015, 11:44:00 AM
I just did their transmission flush and fluid change which my ford dealer is an authorized BG dealer. As far as engine oil I'm sticking with Mobil 1 its been in every car I've owned without fail.
Dbad1
2012 Taurus SHO modified, K&N CAI,3bar,LMS thermostat, NGK gapped plugs, Unleased DP, LMS Thunderstorm Cat back,LMS 4 plus tune, EBC slotted cross drilled rotors, MGP caliper covers, SHO hood graphics, Chrome grill inserts, Continential Purecontact tires
2010 BMW 528 Xdrive
2015 GMC Sierra SLE
myfender
Newbie
Ecobooster
February 26, 2016, 12:39:57 AM
Maybe it was coincidence but after putting in BG44k in my fuel I had CEL's kick in. "massive evaporative system leak" "out of range on O2 sensor" reset and came on the next day, after the next take it seemed to clear up.
Super Moderator
The Tenth Man
#4
February 26, 2016, 12:52:02 AM
You received a DTC PO455?
Forum Supporters
#5
February 26, 2016, 01:08:54 AM
Seems like an extreme case, but not out of the norm. Which vehicle do you have, and how many miles on it? Ever run FI cleaners through the tank before? Checked your PCV system & intercooler to see if there's any buildup?
