Quote from: moem1090 on April 04, 2015, 04:10:34 PM
Thanks for the response. I was thinking it is a fuel pump also. Luckily it happened for me as I was pulling back up to work and I have a shop but unfortunately all of my bays are full so no one can diagnose my car at the current moment. I am hoping it is something they can easily figure out so I can get the ball rolling on Monday. Considering that I do have catless down pipes do you think it is still a risk to drive? It is not doing it anymore
The risk of course is burning or bending a piston or piston rod (and the piston rods in the 3.5 are lacking IMHO due to not being forged, but cast)... your car is knocking because of the misfires of course... and the mixture is very lean if it is the fuel pump... but you hear the knock, even if you didn't check the KR... and predetonation is predetonation. I would not drive it. Ford is not omniscient, but I think the advise of their engineers is correct here... a new engine will cost $6K-$8K plus your time to install and troubleshoot, reprogram, etc... Towing is cheap comparison. You'll decide of course, but I wouldn't drive it.
BTW, the fuel control module on mine did not show up on the OBDII, only the communication code, so if you change the pump and it dies at a stoplight, or at idle, especially if it won't restart...try the fuel control module first.
As an aside... this failure happened to me at 19K miles on a new '13... After the module and pump replaced it runs better than it ever did.. so I think these things can function suboptimally for a long time, hurting performance, before a DTC or noticeable abnormal routine driving behavior... this part is just my $0.02... I can't prove anything but better performance.
