rear turbo oil leak
Started by gad, April 03, 2015, 07:08:33 PM
gad
I read here tsb for this problem, I changed outlet gasket of the turbo,  leak again, seems to come from above. except that I do not see the benjo on top turbo, so can not know whether the loss of oil from the top  (entry turbo oil) anyone know how to watch the turbo from to the top?
10 SHO, torrie tune, whatermeth , DP catless, H&R spring, t-stat 170, air raid intake, best time 12.19@110 mph.(1.74 0-60ft)
Has that banjo bolt ever been removed or loosened?
gad
Not sure how you'd observe from above, more likely need to be on a lift looking from below.  In any case, the resolution would appear to be replacement of the turbo oil feed line, not just a gasket:
http://www.ecoboostperformanceforum.com/index.php/topic,3760.msg58483.html#msg58483
Quote from: SHOdded on April 03, 2015, 10:47:40 PM
This the best advice.  It is possible that the leak is not even the turbo... Get it I a lift to make sure of the oil origin...
gad
Forgot all about that!  You could try an oil leak detection kit as well.  IDK how well those things work on modern turbo engines.
Any luck with tracing that leak, gad?
gad
not enough temp to check the leak this time.
