Hey everyone, thought I'd share some quick pics with you guys from my snow performance methanol install.
Here's the final product starting in the trunk. AEM in-line filter, anti siphon valve, tank, and pump.
Running the tubing and wiring through the back corner of the trunk.
View from rear passenger side where the tubing and wiring lead down into the paneling (removed). I later went back and ran everything behind the seat belt instead of in front of it.
Wiring and tubing running along floor bored/paneling to the front passenger side of the car.
Pump controller mounted in glove box.
Drilled a hole under the front passenger paneling where the power wire, methanol tubing, and boost tubing for pump controller exit underneath the car.
Everything exiting underneath the car.
Methanol tubing ran up through the engine bay following the fuel lines (I believe).
Methanol nozzle/intake pipe.
I ran the boost tubing for the pump controller through the fender well.
Boost tubing spliced into the intake with a T connector.
I also ran wiring underneath the front dash to the driver side for a green LED indicating when the pump is activated and spraying; as well as an amber LED which will turn on when the methanol tank is low.
Overall I was really pleased with the install. I trimmed and stream-lined all the wires and tubing before reinstalling the paneling. It looks like a completely stock SHO on the inside... unless you look into the glove box or trunk!!
It took me and my buddy all day Saturday and half of a Sunday to install. Then began the tuning with Torrie. After numerous data logs and having to the turn the pump pressure up (I'm guessing because it is mounted in the trunk and has a fair distance to pump) the car runs fantastic. Having the tank and pump mounted in the trunk makes for easy refills as well as easy pump adjustments too!
Tomorrow the H&R lowering springs are going in!!!
