Tuning not yielding increased ET's
Started by fastforever, March 01, 2015, 12:46:44 AM
91hybrid
I have a large filter about 6" down from my reservoir to help keep things like this from happening. Cleanliness is key with any fuel system. Good find!
2014 SHO -PP, Unleashed Tuned, 3bar, Devils Own 100% meth, PPE catted down pipes, 3rd cat delete, Magnaflow 2.5" exhaust, 170 deg, NGK 7's plugs, hot pipes - White Platinum 401a
418 whp - 513 wlb/ft
non meth 13.11@103.6 (knock limited)
Meth pass 11.991@114.28
fastforever
Hey 91hybrid, nice times. how loud do you find the exhaust with all the flow?  I am considering the third cat/muffler delete with PPE cat pipes, but leaving stock exhaust from there back. I have a '67 Barracuda if I want loud.
Thanks
Mike
LMS catted dps, 3rd cat/muffler delete, 50/50 meth kit and Torrie tuned = 12.44 at 111+mph at PBIR, south FL.
91hybrid
The cat back added to the sound but it's still not really load. Probably about the same loudness as a stock mustang gt. With stock mufflers, I wouldn't think it's going to be a whole lot louder since your keeping the stock mufflers. So you should be good to save your hearing for the cuda!
fastforever
WELL, Just got my car back from Ford service after a week. New PTU under warranty, apparently if you have the fluid go thick you can toss the PTU....according to dealer. Damage already done, even if cleaned and refilled. The TSB should cover anyone's PTU if returned to stock before going to the dealer. I even had a new steering rack installed and aligned. Maybe now I can the et's down, DPs to come and already deleted third cat and muffler with a crossover pipe.
Not bad :)  Which TSB are you referring to?
