June 19, 2019, 08:17:51 PM
Author Topic: WITH SPRING COMES THE TICK AGAIN  (Read 2339 times)
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1483
  • -Received: 3321
« on: March 22, 2015, 02:14:53 PM »
I have been aware of this tick sound for quite sometime know and also there is a TSB for it and affected are the magority of the 13 PP SHO and also a small amount of the 14 PP SHO are affected,know make a long story short(hopefully)had mine performed at the dealer last summer due to a metal tick sound coming from both front wheels when turning the steering wheel back and forth and when making turns,when this was performed at my dealer there was no TSB for this issue,so they installed new thrust washers and wheel hubs(wheel bearings)and the issue was resolved under warranty until today,as Spring finally came and so did the tick sound,called my service advisor yesterday and the good news was that there are updated vinyl/rubber thrust washers that will hopefully and finally terminate that annoying tick sound coming from the front wheels,he mentioned the 15 SHO has the new updated version,hope this helps someone and will keep you updated and maybe get that annoying noise from the drivers front seat also fixed.Z.
TSB #TSB-13-5-14
NHTSA ID #10052787
Date Announced:
MAY 13 2013
Additional Info:
How to Fix
Summary: FORD/LINCOLN: ON SOME VEHICLES, WHEN ACCELERATING FROM STOP OR SHIFTING BETWEEN DRIVE/REVERSE AND/OR REVERSE/DRIVE, A NOISE IS HEARD LIKE POP, TING, CLICK, COMING FROM FRONT WHEEL AREA. MODELS 2011-2013 TAURUS, EXPLORER, FLEX, MKS, MKT.
« Last Edit: March 22, 2015, 02:21:09 PM by ZSHO »
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|Airaid-Dry-flow-CAI|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|Gearhead Intercooler|First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned @ 415whp-465wtq| Best Trap Speed of 115.54 mph|
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11045
  • -Received: 3663
Re: WITH SPRING COMES THE TICK AGAIN
« Reply #1 on: March 22, 2015, 02:49:02 PM »
Man, I hope it goes away for good this time!
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • : Gilbert - SE Phoenix Metro Area
  • Thank You
  • -Given: 1155
  • -Received: 704
  • Ecobooster
« Reply #2 on: March 22, 2015, 03:39:52 PM »
Thanks for the update Z.... I'm gonna look into that for sure!
2013 Taurus SHO nonPP - All Ford factory options, 3BAR MAP, LMS v8 tune (mods for 3BAR, DPs, and T-stat), Paint & plastic correction, CQuart finest all exterior surfaces, limo black window tint,VLED Triton switchbacks, Daytime BrightLites switchback DRLs, full interior and exterior LED conversion, Lamin-X charcoal blackout tail lights and reflectors, PPE catted and coated downpipes, EBPP coated hotpipes with BoVs VTA, MDesign CAI
2013 F250 CC Lariat 6.7EB Diesel -stock
Offline 4/SHO
  • Jr. Member
  • Thank You
  • -Given: 3
  • -Received: 0
  • Ecobooster
« Reply #3 on: March 08, 2019, 05:10:44 PM »
TSB #TSB-13-5-14
NHTSA ID #10052787
Date Announced:
MAY 13 2013
Additional Info:
How to Fix
I am having odd noise in reverse and when turning the wheel back and forth, especially when in park. Kinda slight grinding noise. I believe it's only in the front and while turning wheels.
2011 SHO with a 2015 SHO engine. She started out as the 2011 SEMA SHO by Rick Bottom Designs. Which had the following-  H&R lowering springs, Baer Extreme brakes, 22 in axiom rims,  Razzi body kit, Corsa performance exhaust,  Airaid cold air intake,  no weeds exhaust diverted, and a few other items. I then took her to National Speed of Wilmington NC where I had bigger ATP turbos, firestorm high pressure fuel pump, catless downpipes, 170 Tstat, 3bar MAP, tial BOV,  EPP pipes,  colder spark plugs, and  HP tune.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1483
  • -Received: 3321
« Reply #4 on: March 09, 2019, 04:47:49 AM »
Does it sound like the below video! If so its your wheel hubs as mentioned earlier. Do you have the Performance package or Non PP! Z
https://youtu.be/BnbCig-wR1Q
https://www.rockauto.com/en/catalog/ford,2011,taurus,3.5l+v6+turbocharged,1446498,brake+&+wheel+hub,wheel+bearing+&+hub+assembly,1636
« Last Edit: March 09, 2019, 05:57:36 AM by ZSHO »
Offline avidmotion
  • Sr. Member
  • Thank You
  • -Given: 2
  • -Received: 66
  • Ecobooster
« Reply #5 on: March 10, 2019, 01:14:19 AM »
I have a 2013+PP I have had that click since I had the car. Will changing to the new rubber thrust washers from a 2015 cure this or would need new bearing too? Is this click just annoying or will eventually fail or break something? It's been doing it 35999 miles for 3 yrs now.....
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1483
  • -Received: 3321
« Reply #6 on: March 10, 2019, 06:59:08 AM »
I would always get a Code C1B00 related to this issue and sometimes changing only the thrust washers would only provide a temporary fix while ultimately the wheel hubs and new updated metal washers should provide a more viable fix.
Need to check the front wheels for play and start from there.  Z
https://www.ecoboostperformanceforum.com/index.php?topic=6676.0
« Last Edit: March 10, 2019, 07:10:19 AM by ZSHO »
* Featured Topics
* Recent Topics
by 5ohSHO | Today at 07:08:46 PM
Ah ok.  Yeah the flowers tend to be on the "softer" sid...
Re: 2010 Lincoln EBAP Photos
by Black Dream | Today at 06:35:32 PM
I test drove a 2011 Red version that had the exact same interior as yo...
Re: Glad to be here
by Black Dream | Today at 06:27:40 PM
Our poor dead G is being slowly parted out.  She was not my daily...
Re: Center caps on flowers
by 76fomoco | Today at 06:22:32 PM
you must have been without wheels at your location and or no batteries...
Re: Water in passenger floor
by Agentlongwood | Today at 05:48:48 PM
After all that, it didn't fix the leak lol.  It looks like m...
Re: battery terminal
by GhostlyGrenade | Today at 04:10:04 PM
Well I ordered a new battery as well as the updated rear trans mount. ...
Motircrafts SP-542 Spark plugs!
by ZSHO | Today at 03:14:45 PM
FYI- I noticed there is much interest in the SP-542 PLUGS and will be ...
2019 SHO Convention - Alternative Has Been Announced!
by SHOdded | Today at 02:53:36 PM
Since the official 2019 Convention is not happening, an alternative co...
Re: Gearhead SHO/Flex Intercooler Install Video
by Leadfoot | Today at 10:53:16 AM
I recalibrated my SHO, unfortunately with a MKS/Flex hybrid calibratio...
Re: Random thoughts for the day
by SHOdded | Today at 05:58:42 AM
Bulk shipping is expensive from the dealership.  But different de...
Re: Gearhead Intercooler Review
by avidmotion | June 18, 2019, 05:28:15 PM
....Me too....      :)...
Re: Power per mod discussion
by Black Dream | June 18, 2019, 03:31:45 PM
I could be wrong but I think he meant a Coors Light.........
Re: 2013 SHO Throttle Body Adjustment Screw Leaking?
by SHOdded | June 18, 2019, 08:57:10 AM
A nice little side project :D...
Re: R134a capacity
by Three Lions | June 18, 2019, 07:34:28 AM
Thanks guys. Most appreciated...
Re: Hotpipes, Meth Bungs and Nozzles
by shoNoff | June 18, 2019, 07:11:45 AM
I got lucky mine still had just enough sticking out so I could grab it...
Back to top
