Started by r1crusher, March 13, 2015, 02:08:06 PM
Quote from: PokerMunkee on March 13, 2015, 02:27:19 PMSomeone with a 2013 SHO put it in his car. I believe he works at Ford, so he knew what he was doing and got the parts. There is a thread somewhere with pictures, either here or shoforum.com
Quote from: Gray Brick on March 13, 2015, 07:51:58 PMMiracast to Sync would be a huge upgrade.The new Sync 3 is still the same system with a few upgrades.
Quote from: J-Will on March 13, 2015, 08:18:30 PMQuote from: Gray Brick on March 13, 2015, 07:51:58 PMMiracast to Sync would be a huge upgrade.The new Sync 3 is still the same system with a few upgrades.The same what? They've moved from Microsoft to Blackberry. Most of the hardware will probably be newer versions or similar to current gen. Sync hardware is actually pretty inexpensive at wholesale.
Quote from: BiGMaC on March 13, 2015, 09:04:07 PMLatest I'm reading is that to use the RIM QNX version of sync you'll have to have the new hardware...Ford apparently has no plans for an upgrade path.
Quote from: r1crusher on March 14, 2015, 10:37:32 PMQuote from: BiGMaC on March 13, 2015, 09:04:07 PMLatest I'm reading is that to use the RIM QNX version of sync you'll have to have the new hardware...Ford apparently has no plans for an upgrade path.Well that pretty much sucks donkey balls.
Quote from: SHOdded on March 19, 2015, 09:45:47 AMInteresting. Link to article(s)?
