Anybody had the OE injector flow tested?
You lose pressure (with ethanol or whatever) becasue your injector pulse width decreases with engine speed, your duty cycle increases, your injectors are staying open near continuously and so the high pressure pump struggles to compress fuel, as the restriction eases.
Unless I am mistaken, the rail pressure in these engines is dependent on engine speed, correct? The HPFP is cam driven. It could potentially be responsible for some pressure drops or lean conditions, high load, low in the RPM band.
So, as stated by aj, your injectors can potentially flow well enough, but your limitation is with the HPFP. If there is replacement availability for that, then you open up more headroom for fuel. Until you max the injectors out. O_o
