New EBC pads and rotors all around!!
Started by FLOSHO21, March 06, 2015, 09:36:34 PM
FLOSHO21
What a huge difference!!!  This car finally has brakes like it should!!! I have the 13' master cyl and booster too top it off, and it stops on a dime now! Red stuff all around with the same rotors all around! Highly recommend.
2010 SHO Platinum non PP
H&R springs, K&N panel, NGK-6510, 170 T-stat, Unleashed Tune, 3 bar, 13' MC/booster, Unleashed 3" DPs, W/M
12.74@108.5 3/15
8.07@86.5 best 1/8th 9/15
Look great...man I need these too. I can handle the squishy pedal in normal driving, but at the track those high speed stops suck.
Rich
Brakes now working the way they SHOULD be.  Might start getting rearended by supercars though, so watch out!
markssho
Nice! And no problems with stock wheels?
Quote from: markssho on March 07, 2015, 06:33:00 PM
I think he is just using stock size replacement rotors and pads. And even with 14" rotors you only need 18" wheels
Looks like according to centric brakes that his fronts are 12.81" and rears are 12.99" So he could probably even run 17" wheels
vernonator
Quote from: FLOSHO21 on March 06, 2015, 09:36:34 PM
So can I ask what the damage was for this? I am going to need brakes this spring and would love to do the upgrade.
2012 Tuxedo Black SHO w/PP. Livernois Stage 4+, PPE Catless DP's, EBC Stage 4 Front/Rear Brakes
2015 Tuxedo Black Explorer Sport 401A, no mods....YET :)
peppelepugh
#8
if you shop around enough, i know i got my set for around $560-ish shipped. Mine are slotted only though.
http://www.placeforbrakes.com/product.php?pk=1744&cmk=30433&car_year=2011
2011 Kona Blue SHO non-PP: MDesign Carbon Fiber CAI, All interior lights LEDs, LED Puddles, and LED Reverse.
EBC Stage 4 Brake kit, 170* T-stat, 3-Bar MAP, NGK Plugs, PPE Catless-DPs and Tune by Torrie!
FLOSHO21
Everything is stock size.  The pads were $100 per set, rear rotors were $250 and front were $375.  You can probably find better deals out there but I liked the look of these rotors.
12.74@108.5 3/15
SHOw-Me State
Hey FLOSHO,
I believe your pic in the thread is the rear brake, correct?  If so, just a question regarding the rotor.  You and I having non-PP cars and 10-12 year, believe we have solid rotors stock.
Guessing there is no clearance issue with going to the vented rear rotors and still using stock calipers?
2011 SHO non-PP, Ingot Silver, 2013 fender vents, all stock (for now).
Future: Tune, 3-bar, new plugs.  Catted DP and exhaust someday.
FLOSHO21
Yes, the picture is of the rear.  I couldnt say for sure if the calipers would clear vented rear rotors, or if the caliper bracket would clear, looks like it would be tight for the bracket.  I stayed with the factory solid rear rotor.
12.74@108.5 3/15
SHOw-Me State
My bad!!  Looking the pic closer, I mistakenly thought the inboard dust shield was part of your rotor--thus thinking it was the vented rotor you had.  Thanks for your post clearing it up for me!
Bosscav
FLOSHO, can you elaborate on your 13+ booster and Master cylinder? I am going to make the swap in my 2010 this spring. Did you make a post about that anywhere? Should I PM you for more info?
2010 Ford Taurus SHO, White Platinum Tri-coat Metallic, 402B options package, 20" Nickel Aluminum wheels, purchased 6/26/2014 with only 17k miles. Previous owner: Little old woman who bought it for the heated leather seats...
FLOSHO21
There is a writeup in the "how to" section on this forum I believe for the 13' swap.  Its really not too difficult at all, the hardest part is bending the line into the master cyl just right and installing the brake switch.
12.74@108.5 3/15
