This is a place holder for info on Virtual dyno and how we can utilize it for our cars by using SCT logs and 3rd or 4th gear pulls on a flat road to review our HP.
Why would you use this? If you're using a mail order tune you can take data logs for the tuner that will allow them to see what your car is doing. If you are playing with timing you want to get to a place where more timing doesn't add more power, you can only see this with a dyno. By utilizing this program you can get the car really close what the maximum output possible without spending HOURS for dyno time. After you think you're close THEN you head to the dyno to do some verification pulls. I'm getting my car dyno'd this week with the new turbos, I'll go out and do a log afterwords and do a comparison. Heck I'll do a log on the dyno for a comparison!
Vehicle tech specs:
Flex/SHO/Explorer Sport transmissions ratios
1 4.481:1
2 2.87:1
3 1.84:1
4 1.41:1
5 1:1
6 .74:1
R 2.88:1
Final Drive 3.16:1
SHO PP
Final Drive 3.39:1
F-150
1 4.17:1
2 2.34:1
3 1.52:1
4 1:14:1
5 .86:1
6 .61:1
R 3.40
Final drive options:
3.15, 3.31, 3.55, 3.73
Weight options:
SHO weight 4224
Flex weight 4781
Explorer Sport 4921
RCLB 4x2 4938
RCLB 4x4 5140
SCABSB 4x2 5374
SCABSB 4x4 5564
SCREWSB 4x2 5287
SCREWSB 4x4 5625
SCREWLB 4x2 5492
SCREWLB 4x4 5745
Frontal Area (these numbers look WRONG but can't find good info):
Flex 25sq ft
SHO 28.95 sq ft
Explorer Sport 20 sq ft
F-150 36 sq ft
Drag Coefficient
Flex .355
SHO .32
Explorer Sport (can't find it)
F-150 .416
Download Virtual Dyno here:
http://www.virtualdyno.net/These are things I've researched for my car, we'll be adding all the other platforms information as well.
I will also do a video on how to use the program as soon as I can, need to get the car back from the shop first.
Virtual Dyno facebook page:
https://www.facebook.com/VirtualDynoAnother how to on Virtual Dyno:
http://forums.evolutionm.net/evo-dyno-tuning-results/619146-how-use-virtual-dyno-properly.htmlhttp://youtu.be/SSY2ohtHiIwhttp://youtu.be/1THnCP5vxvUhttp://youtu.be/pZWVHAhE77ohttp://youtu.be/3c2pN06oPlMI am attaching a Ford Flex profile I built. I will also create a video to show you how to use it. The video will work for SCT csv file.
