My stock SHO needs mods!
Started by ChiTownSHO, January 27, 2015, 11:41:50 PM
Quote from: ajpturbo on February 01, 2015, 07:57:23 PM
The boost spikes are not contributed to the 3 bar at all. But it does allow the ecu to properly fuel during a boost spike that comes from the tune...there are only 2 values that need changed in the entire tune to make a 3 bar installed sensor work with stock boost levels
Get a 3BAR... and the tune mod for it... It allows more incremental adjustments by the ECM which makes it run smoother on pulls... Don't care about spikes per se, especially with the SHO's small turbos.  I am very happy with what the 3BAR did for my car.
#46
Quote from: BiGMaC on February 01, 2015, 08:37:59 PM
Actually it's the opposite. The bigger range of pressure that the 3 bar is able to see means that you lose resolution. It's using a 0-5 volt signal to detect full vacuum to 28 or so psi. The stock sensor also uses a 0-5 volt signal but only to see a range of full vacuum to 15 psi or so.
But  there is enough resolution that it's not a problem.
Glassman710
Quote from: BiGMaC on January 31, 2015, 05:11:21 PM
Quote from: Ghwinokur on January 31, 2015, 04:06:46 PM
What will the 3bar MAP do for improvement?  Do you get a lot of benefit by changing the thermostat?
Thanks,
Greg
Welcome Greg! The 3BAR will allow the ECM to use any boost above 14.7 psi in running the engine.  What I noticed most was a more incremental and smoother running car. You will have to have a tune to run the 3BAR.... Without the tune the car runs like crap if it even starts.
Most tuners recommend... Or require... The cooler T-stat for tuning to the highest performing tune.  It takes longer to heat soak with the cooler T-stat, but the real differences do not seem to exceed 10 degrees or less in routine driving.
Might want to put at least the make and model of you ride in your signature to get you the best answers.
Enjoy the forum.
when i return the car back to stock i know i have to put the 2 bar map back on. what about the 170 thermo? do you have to switch that out back to stock also or can i run the stock tune with the cooler thermo with no problems?
2013 SHO with Performance Pack, SunTek CXP 18% Tints, Corsa Cat Back Exhaust, K&N Drop in filter, Unleashed 93 octane 2 bar tune. 12.75 @ 107.71 @ palm beach raceway, Florida DYNO JET 346.27 WHP 385.95 WTQ
No worries with the thermostat.  Keep it in there.
Glassman710
I had the pleasure of running my car stock with the Reishe 170stat and plugs at 0.30 so many times visiting my dealer which is a 120 mile round trip with no issues at all,figure over ten times for warranty repairs and recalls,the cool part is my car sounds louder in stock mode,and you appreciate your tuners capabilities even more making it that much more a pleasurable experience.Z
CL Donttry
What does PTU change mean? Is that synthetic oil not sure what it means.
Dbad1
2012 Taurus SHO modified, K&N CAI,3bar,LMS thermostat, NGK gapped plugs, Unleased DP, LMS Thunderstorm Cat back,LMS 4 plus tune, EBC slotted cross drilled rotors, MGP caliper covers, SHO hood graphics, Chrome grill inserts, Continential Purecontact tires
2010 BMW 528 Xdrive
2015 GMC Sierra SLE
Power takeoff unit oil change...its synthetic oil from the factory...albeit garbage fake synthetic
For the price, you are better served with aftermarket brands like Amsoil or Royal Purple for the PTU fluid.  Key is still to check/change every 25-30k miles.
CL Donttry
Ok I will get that done wasn't planning on changing my transmission fluids with the mods I had but now on my list thanks.
Dbad1
2010 BMW 528 Xdrive
2015 GMC Sierra SLE
