DynomaxVT mufflers
Started by TooFast4SHO, January 22, 2015, 02:29:38 PM
BigPelo
Well, I tried the Dynomax VT 17962 on my WRX and I am not impressed. The valve starts opening at 2.5k rpm even though it's a 2.0L engine making 0 boost at that rpm and the muffler is supposed to be design for +4.0L of engine displacement. On cold engine/muffler startup it makes clunking sounds. When everything is up to temp, I need to be so easy on the throttle to keep it silent it's not even fun.
The sound at WOT is good though and at US$90 it is a fun experiment.
Where's the thing I should probably have bought, and will probably do:
http://www.ebay.com/itm/Remote-Control-3-Inlet-4-Outlet-Tip-Exhaust-Muffler-W-Electric-Valve-Silencer-/301072200376?hash=item46194d32b8&vxp=mtr
Week-end family transporter: 2013 SHO tuxedo black, performance package, unleashed custom 94 octane tune, K&N Typhoon intake, 170F thermostat, 3 bar MAP sensor, SP534 spark plugs, 5000K HID Morimoto mini D2S projectors retrofit, tinted windows, Full LED lighting in and out, Eibach springs
Daily beater: 2002 WRX wagon swap JDM STi v7 20G'd
cseverens
Quote from: TooFast4SHO on June 23, 2015, 12:28:02 PM
I tried the 2.5" Vt's on my SHO with PPE Catted down pipes and no 3rd cat or resonator and the car just buzzed under throttle and sounded horrible. I put the stock mufflers back on and I have been happy like that... Hard to describe the hum under load the mufflers made like an forlorn bee or something was not good.
I am leaning heavily towards these mufflers. I have catted dp's as well, but the rest of the system is stock. not removing the 3rd cat or center resonator. I'm thinking the buzzing you had was maybe because you deleted those, and/or went to 2.5". I plan on going with the 2.25"...p/n 17155 I believe. thoughts?
2013 Ford Flex Limited E/B
cseverens
been on for a few weeks. I love them.
J-Will
Quote from: cseverens on October 26, 2016, 01:13:43 PM
What size did you go with?
3-bar
SP-542 plugs w/ GH gap
cseverens
Quote from: J-Will on October 26, 2016, 05:28:00 PM
2.25" in and out.
I had also bought dynomax tips (2.50" in, 3"out), but they are too short (6"). I have since ordered longer ones (2.50" in, 4" out, 11" long) that should be here Friday.
J-Will
Cool man, post a vid when you can. I'd like to hear it.
And rasp or drone?
3-bar
cseverens
Quote from: J-Will on October 27, 2016, 09:16:11 AM
And rasp or drone?
zero, none, nada
J-Will
Quote from: cseverens on October 27, 2016, 09:20:27 AM
And rasp or drone?
zero, none, nada
Yup, I want to hear it man. Esp with downpipes.
3-bar
cseverens
it's about 20* out right now. if it warms up later, i'll give it a whirl. shitty cell phone video though I'm sure.
cseverens
J-Will
3-bar
cseverens
