**HELP.....AGAIN.....**
Started by SHO-TYM, January 18, 2015, 05:13:17 PM
SHO-TYM
Quote from: peppelepugh on January 19, 2015, 09:10:09 AM
If it helps at all. When i installed my new gapped plugs and tune back in Dec. I MAY or may not have forgotten to hook one of the coils back up.... surprisingly the car ran on only 5 cylinders. Idle was a bit rough, 1.2k to 3.5k was fairly smooth, then after about 4k the car would just fall flat on its face.
I don't know much of anything about the Meth systems, but maybe this little bit of info can help!
Thanks for the input. I will probably be changing the coils and plugs this time to ensure I don't still have the same issue
2011 Ford Taurus SHO non PP, Livernois Motorsports Windstorm Intake, LME Stage 4+X Meth Tune, 160* thermostat, new motorcraft plugs gapped at .028. 3 Bar Map Sensor, LMS non-catted down pipes, Corsa Catback System, ALKY Methanol Injection, LED Puddle Lights, and (ATP upgraded turbos on the way)
Road & Track Article
http://www.roadandtrack.com/car-culture/news/a25497/this-is-what-a-550-hp-ford-taurus-sho-looks-like/
