Wow. Ton of replies..
Torrie sells the 6510's (1 colder 6509 is stock), I'll have to see if he pre-gaps them. I usually order my NGK plugs from a site in Canada with free shipping ($9.29cdn here each)..
www.clubplug.ca Now I understand the need for 3-bar MAP, Torrie's reply was a bit confusing! Makes perfect sense. And I am seeking more boost so this is a requirement....
Panther427- Thanks for the write up, sounds easy! Do you use your stock box with a panel filter or the stock paper filter?
I gap plugs using feeler gauges as well, I hate those "spark plug gapper tools".
I like the idea of the AEM dry panel filter. But if the stock will do the trick, I'll stick with that.
As for warranty.. Return to stock, Swap back to a 2-bar MAP. What about the plugs? I've read about the TSB's on detecting after-market mods etc.. So I'm well aware of this.
Ben
