Truthfully, we don't use throttle body upgrades because these cars do not need, nor benefit from an aftermarket throttle body. Add into this the lackluster reliability of aftermarket throttle bodies in DBW vehicles, and it becomes even clearer why to avoid them.
I can answer a question on downpipes for you in Cali. NO aftermarket downpipe will pass in Cali, this is because it is illegal to remove a properly functioning cat, and then it's also illegal to relocate the car from it's original location, if by chance you actually were replacing a faulty cat. You might be able to scrape by in another state that actually does sniffer tests with an OBD-II legal cat, but Cali always does a visual as well and it would be an instant fail. They just don't play around in Cali.
