Ecoboost Performance
Ecoboost Tuning!
Datalogging and Gauges
Datalog to Dyno Chart with LiveLink Gen2
Started by Gray Brick, December 12, 2014, 07:43:20 PM
Gray Brick
Sr. Member
Gray Brick
Is it possible to make a virtual dyno sheet using the SCT LiveLink Gen2?
I tried the program Virtual Dyno and it gave strange results.
2013 Ecoboost Ford Flex
Forum Supporters
Re: Datalog to Dyno Chart with LiveLink Gen2
December 12, 2014, 10:41:00 PM
AFAIK, you get the numbers from LiveLink, then use Virtual Dyno to translate that into a dyno graph. What results are you getting? Post them up ...
Gray Brick
Sr. Member
Gray Brick
December 17, 2014, 12:51:21 PM
Here you go...
Gray Brick
Sr. Member
Gray Brick
March 09, 2015, 10:48:42 PM
The 1st graph looks reasonable.
booooost
#4
March 10, 2015, 09:53:07 AM
Why are the graph such a small rpm window?
Gray Brick
Sr. Member
Gray Brick
#5
March 12, 2015, 03:39:27 PM
Only 3rd gear from a 0-100mph run
Ecoboost Tuning!
