Quote from: crash712us on November 11, 2014, 03:59:31 PM
Best possible torque split is 50/50 as the PTU is driven off the passenger front half shaft. As for the 150ftlb max torque spec, it's been so long ago I don't even remember where that number even came from. I would definitely like to talk to the person at LMS that told all this. Better yet I will go straight to Dan to get hear right from the horses mouth.
Agreed. Except I will say a halfshaft, I believe, is generally what is used to refer to a drive axle or propeller shaft on a transverse mounted engine car. Half shafts emerge from the transaxle.
The PTU is driven by a shaft from the transaxle, with the half shafts carried from the PTU, in addition to the PTU carrying the shaft which flanges to the drive shaft. The driveshaft is continually propelled by the carriers in the PTU, but only sees load when the rear clutchpack is actuated to the RDU, and them from there to the rear wheels.
If it is arranged in this manner, it is not mechanically possible to drive a rear bias. It would need a center diff or viscous coupler.
