Apologize been a little bit under the weather as of late,first of all hopefully you resolved your issue,on my last post asked you for a reason regarding your mpg,cause as of 9/1 we started to use winterblend gas and me personally i'm getting 13.4-14.0 mpg with almost the same tune as you,with the sacrifice of the mpg you should see better performance out of your car compared to before,glad you gapped the plugs at 0.30 the more boost the closer the gap has to be to prevent misfires,spark blowout,predetonation.
