Finally got my '14 in the 12's
Started by 91hybrid, September 20, 2014, 11:16:49 PM
Asked Torrie if a little extra shot of ethanol would push you into the 11's?  :D
I've tried a E Brake burnout before. Works fine on the street, if done correctly. But at the track it sounded like the engine banged against the firewall. So I don't do it anymore, but stiffer engine mounts would be helpful.
91hybrid
That's a good heads up. The motor mounts do seem pretty squishy. Maybe we should see if mike can help us with that too.
2014 SHO -PP, Unleashed Tuned, 3bar, Devils Own 100% meth, PPE catted down pipes, 3rd cat delete, Magnaflow 2.5" exhaust, 170 deg, NGK 7's plugs, hot pipes - White Platinum 401a
418 whp - 513 wlb/ft
non meth 13.11@103.6 (knock limited)
Meth pass 11.991@114.28
Quote from: SHOdded on October 18, 2014, 05:01:40 PM
Lol, read my mind...
91hybrid
Quote from: FoMoCoSHO on October 18, 2014, 06:43:14 PM
I could put in some 102 with the meth and turn up the timing more...maybe next season. Tomorrows the last race for me.
Good luck tomorrow. Cmon HUGE tailwind!
Rich
91hybrid
Thanks for the comments. Not looking for any home runs, just base hits. Next target is 12.1x, after that, 12.0x and so on. She'll be in the 11's one of these days...I think. 😜
91hybrid
Well, it wasn't in the cards today boys.  Looks like the combination of the tune changes torrie and I made and a little slicker track made for 3 terrible passes where it spun so hard that it wouldn't complete the 1-2 and or the 2-3 shift.
Looks like I will be investing in some drag only front wheels and tires for next season.
http://youtu.be/eoWQEXWU4Fg
boostedbull
Quote from: crash712us on October 18, 2014, 05:14:18 PM
How are you doing this without destroying the awd system?
2012 SHO PP - Tuned by Torrie
12.8 @ 106  tune only
91hybrid
It's all about tire diameter. Must be the same.
Barely engaging the e brake disables the awd system.
Just 1click is usually enough to turn the e brake light on.
Quote from: boostedbull on October 19, 2014, 10:15:24 PM
I think if you try to drive with the E-brake engaged, the car will automatically shut down AWD to protect it.
91hybrid
Yeah, I tried to do a ebrake burnout. Didn't work to well.
Quote from: 91hybrid on October 19, 2014, 10:21:29 PM
3% difference max.
