hi guys I just want to share with you that I am a proud owner of a 2014 sport, And from day one I drove it stock it was nice but just another jeep honestly , Anyway I read and made my research and decided to go with torrie (unleashed) because I am not in the USA and need someone to tweak the tune a lot to our fuel (98) which is similar to your 93 and our hot weather which reaches 130f easy, After I tried his tune on the stock form with back and fourth dataloggin and sharing knowledge and what I see in the data log and feel I got the best map in stock form.
I then decided to go with his thermostat, 3 bar map sensor, I got catchcan , and a front pct delete with crank case vented filter in the oil cap position, air intake, and x4, I then added distilled water and water wetter and he also helped me the proper bleeding procedure to match our hot weather and asked him to tweak the fans to comeon fully at 192 and this is the best and makes a big difference just as big with the catchcan setup, After 3000km only I found s*** loads of oil in front catchcan and on the filter.
Anyway cutting the story short before the mods I was at 15psi and now with the mods I am in between 17 to 19 peakin 20-21 sometimes, without methanol and no knock or lousy misfires wht so ever even in our hot weather, It took us maybe 8 maps or so to get it perfect and exactly how I want it in shifting, wot and over all driving experience.
I took off the air raid intake since the car was heat soaking like hell so I don't advise it at all or any intake on these cars unless a closed version is out or something.
Anyway i am sure someone else not picky as I am would be fine with the first map he sends but I am very picky and I always want the best, and I got it .
thank you unleashed tuning from the other side of the world
mohammad
p.s excuse my English guys and grammer mistakes
