Ford dodging warranty work!!!
Started by jimmyducati, September 08, 2014, 05:00:11 PM
wasinger3000
Quote from: FoMoCoSHO on September 09, 2014, 06:16:32 PM
Quote from: wasinger3000 on September 09, 2014, 02:00:21 PM
Ok... so how can someone change oil on their own. I'm sorry but this isn't a fascist  ****ing state. I'll change my own oil on my property when I see fit. If they cannot honor their word on a warranty then It's time to take their ass to court.
s*** really pisses me off. Now I have to keep a record of my oil changes so they can eat s*** when it's time for warranty work.
To be fair, you'd be surprised how many people do not change their oil.  Most peeps just aren't fanatical about maintenance like we are. And yes, they go into the dealership and expect ford to pay for their irresponsibility.
For simplicity I take my own oil and filter and pay 12.94 cents for the labor. One I no longer enjoy working on cars, two, there is never any issue about proper maintenance.
Yeah I see the other side of it now. I was raised in an environment where my father showed me how to fix what was broken and how to maintain equipment. So it is just second nature for me to change oil. Never once considered having someone else do what I can do myself.
13' GTCS, will be missed.
black99lightning
Quote from: wasinger3000 on September 09, 2014, 04:48:05 PM
Quote from: black99lightning on September 09, 2014, 04:10:20 PM
I think it would be pretty common knowledge to keep track of your oil changes.  When I used to do my own oil changes, I kept the autozone reciepts showing oil and filter. It had a date and I would write on it the mileage.  Ford is only insuring you've put the correct weight, and it's been done on the recommended interval.
Or save the hassle and let the dealer do it for you.  $45 for oil/filter and tire rotation.  Hardly worth the $5-10 savings to go to the store, jack the car up, crawl underneath, and dispose of my own oil.  I take the Taurus and the Xsport to the dealer.   I get the guys to change the oil in my GTO and Lightning as they are way passed any warranty days.
I've always changed my own oil. I don't do it to save money or because It is easy. I take pride in my car and I choose to take care of it to a higher standard than my local dealer can offer.
As well as being able to use a superior oil than the dealer can offer. I have a record of all my oil and filter purchases via amazon. Now all I need to do is note the milage.
When I was younger I did all of my own oil changes.  As stated I or one of my techs will change the oil/filters in the GTO/Lightning.   But for my cars that are under warranty, I let Ford do it.  They have a record of maintenance and should something arise, it'll be on them.  The GT500 will probably go to the local Ford store also.  They use a full 5/50 synthetic for those cars.
Believe me on my other vehicles I do plenty of high performance upgrades, myself.
2013 Esport 13.44 @ 103.6
1999 Lightning 12.44 @ 108.4
2012 GT500 10.96 @ 130.6
2006 GTO 12.83 @ 107.8
2013 CTSV coupe 11.79 @ 119.7
I concur with all said... I do think ford and other manufacturers avoid warranty work... But it is the primary source of their shops income... So a good dealer relationship can still help.
I ran into this problem of documented maintenance once myself.  I let the Ford house do my oil changes an they do it with the Amsoil synthetic I supply.  I take bulk containers so they have to give me the partially use one back... My check on them.
SD13SHO
My last car was a 2011 Mustang GT/CS. I had the dealer do the oil changes as I found they did good work and I was in and out in less then 30 minutes. During one appointment for an oil change I asked then to check a noise in rear end. The service writer came out 20 minutes later and advised me they had a loaner car for me. The tech had pulled the cover off the differential and found the gears chewed up. They ordered parts.  I received call the following day and the service writer advised the parts had come in that morning and were installed; however, the tech was not happy as he felt a vibration while test driving the car. He called Ford, and they were going to replace the drive shaft. Ford overnighted a drive shaft, it was installed the same day it arrived and I picked up the car at 3:15. This was a total of three days.  This dealer has been servicing my SHO since the day I picked it up, almost two years ago. Same great service. The car(s) are always as clean as when I brought them in. They cover the steering wheel and seats and put paper mats on the floor. They know me by name, and always greet me. I have had the same service advisor since I bought the Mustang, in 2010.  I consider myself fortunate, and because of this dealer's service I will being buying another Ford from them.
"Old age and treachery will overcome youth and skill every time"
2015 Mustang EchoBoost
jimmyducati
Quote from: IHeartGroceries on September 09, 2014, 05:39:27 PM
I've kept receipts for oil/filters, with mileage written on the back since I was 16 years old, with my first car. It strikes me as odd that it isn't common sense for anybody to do.
You guys act like Ford does not deserve to be apprehensive. You know how some people treat automobiles....many people are devastatingly neglectful when it comes to auto maintenance, even as simple as routine oil changes. And why should Ford pay to repair such a neglected vehicle? So, they want to see proof of maintenance, before they honor their warranty. I don't see the issue.
Just chalk it up as a learning experience.
I literally have a folder for every vehicle I have owned, with every sales receipt for any part or maintenance I've ever spent on it. May be a good idea to begin something similar.
Chalk it up to a learning experience??? When they basically void your warranty because you didn't keep receipts for the quantity and grade of gasoline you put in your car when you take it in to have the ignition system checked, I guess you'll just have to chalk that one up as a learning experience huh... They refuse to repair a KNOWN problem on a car that is very obviously well cared for. There are other ways of seeing that service has been recently and routinely done on a car without being as petty as requiring receipts at every corner... The oil filter is obviously new, the oil is new, all of the air filters on the car are cleaned/replaced regularly, the car is spotless inside and out. If they are that concerned with the oil weight, they can have it tested (this will tell them more about my oil changing habits than any amount of receipts would) and I would even volunteer to pay the $50 it costs!
This is Ford getting out of a service claim using any way they can, knowing that average joe dosnt have the legal backing to fight it.
2010 White SHO w/two tone interior
2005 Ducati 999s  (the daily ridder)
1998 Ducati 916  (the beauty queen)
1995 Ducati 900ss (the track terror)
1978 Harley Davidson Shovelhead
Quote from: SD13SHO on September 09, 2014, 11:27:03 PM
There you have it!  This should be expected of all dealerships, but the %age is dropping.  Always know your customer, and customer will show appreciation right back.
Quote from: jimmyducati on September 10, 2014, 12:45:56 AM
Agreed.  But I would keep pursuing the issue with Ford (maybe even with Lincoln instead, they seem to be friendlier) and with the dealership's top management.  AND, despite your right to be angry at them, I'd be as friendly/calm as possible.  Honey vs vinegar.  Hard to do, but might be worth it.  I too expect straight talk, but have learned over time to escalate the issue and be politely persistent.
mval
manu:
i normally agree honey works better than vinegar. but when you go above the dealer level i don't think at present with ford, & i'll bet they are not alone, that works. larry problem is a very real & potentially dangerous tranny problem & jimmy problem they are nitpicking him. i think in last maybe couple years the bean counters have gained an upper hand over marketing & the dealers are being squeezed on warranty repairs. in most cases we all know if was up to the dealer, he would do warrant work, a money maker for the service dept. but just a fact of corporate short term quarter by quarter view of their business. luckily on my tranny i could make it happen, even then was originally given, the maybe you'll have to live with it line.
mikev
'10 lme 4+93, 160t, 3 bar, w/cust headrest & evo gauge pod,md design cai, ppe dpes, borla cback , vertini 20" cust wheels w/conti dws, ebc slotted rotors w/red pads & mgp caliper covers, viper remote start, cust dipped eng cover,fascia, cai & lids,decals, custom bra, black wrapped spoiler
2017 chally scat pack shaker yellow jacket dd, so sho can be a show queen
Quote from: mval on September 10, 2014, 09:49:54 AM
manu:
mikev
The second part is an incorrect assumption. Warranty work pays less than customer pay.
They cannot void the warranty work on the entire car because proof can't be provided for oil changes. Also, the dealer cannot void the warranty as they are not party to your warranty contract with Ford.
Quote from: FoMoCoSHO on September 10, 2014, 10:17:41 AM
Physicians get rated by insurance partly on the basis of the number of tests they order.  The fewer the tests, the better rating the doc is likely to have.  There may even be bonuses involved.  Is there a similar relationship between Ford & the dealership?
mval
not to nitpick you but i will. what i meant was they get paid by ford to do the warranty work. maybe they don't get the markup on parts or ford pays them less than they would charge a customer for hourly labor but it sure beats the dealer union techs sitting around drinking coffee. thus it's a money maker for the dealer.
Quote from: mval on September 10, 2014, 11:18:36 AM
Techs are not in a union and with about 21 current recalls, I assure you techs are not sitting around drinking coffee.
As far as it being a "money maker" why would you think techs and dealers would like to do the same job for less money?
You's be shocked at what Ford pays for some of these jobs.
The difference is that good dealers and techs understand that taking the hit on warranty work is an opportunity...Do the job, treat the customer well and at some point the warranty work is over and it turns into customer pay. Some dealerships however, can't see the big picture and do what they can to blow off warranty work because it pays so much less.
^It's amazing how accurate this analysis is.
And yes, a learning experience. I would hope that anybody who'd come away from this experience would make an adjustment. Shoot, even coming away from this thread. I mean, how hard is it to save some receipts? Really?
Its not just Ford. Ask any dealership for any make, and chances are your service advisor or manager will suggest you maintain records of your maintenance.
It works this way with any warranty backed consumer produce, which might require maintenance or care.
TooFast4SHO
#42
LOL @ Produce from IHeartGroceries sorry I chuckled, about using the word Produce, not about what you were trying to say...
I think it is unrealistic to expect receipts to honor warranty work. A lot of receipts now are thermal and fade after a few days or weeks then what? Take a picture of the receipt next to your ODO to keep track? Tell me that can't be faked. They need to do an oil analyses to make their determination or something that would actually tell them something useful. And all this should be common knowledge folks need to plan for the eventuality they do not believe the receipts you have are for what you say they are just because you have them and say it, your word does not automatically make it so.  Where on the receipt does it say you bought the oil for a specific car (based on a generic multipurpose filter part number?) and ever actually put it in?
Nothing about that makes any sense...
I could see trying to blame it on aftermarket parts or something but an external oil leak on a turbo would lead most to believe a defective seal or supply/return line. If it was consuming oil and smoking or something then maybe a tune did it but come on....
2014 SHO non PP, Livernois 3bar v8 tune, PPE Catted Downpipes, 3rd cat delete with straight pipe stock back, H&R Dropped Springs, Low Temp Thermo. Adaptive Cruise, Collision Avoidance, Lane Keeping, Auto Brights..
12.99 @ 106.4 with 3/4 tank of gas and spare etc. in car.
X2 on this ^.  And Jimmy already offered to have the oil analysis done.  I don't think we need to escalate things to an NCIS or FBI level investigation in order to get his SHO fixed and back on the road.  The mechanics need to do their job, see what failed, write up their report.  Guilty until proven innocent, my a**.
wasinger3000
