hi, trying to find the previous owner or at least figure out my new 2013 SHO
Started by Black Coyote, August 27, 2014, 09:01:19 AM
Quote from: PokerMunkee on September 19, 2014, 10:16:49 AM
The ticking noise is the hubs.  I'd get the better aftermarket ones and install myself.  The OEM ones will fail again I'm sure.
Why would you say that,just curious do you hear or feel anything?
PokerMunkee
Isn't he hearing this?
http://youtu.be/38Yw1I6UkVg
My thread: http://www.ecoboostperformanceforum.com/index.php/topic,3140.0.html
If Ford won't pay to fix their deftected crap, then buy yourself the heavy duty Timken hubs and install them yourself or pay a cheap mechanic.
2011 F-250 6.2 CCSB FX4
Black Coyote
If I had extra money to blow I'd get the aftermarket ones.. but I'm glad you came an share your insight, because I thought I read somewhere on here about the upgrade ones being better. If I can get it done under warranty I'm let them do it for free..If it fails again I'll do the upgrade
Black Coyote
Smh..what does service advance trac mean? Came on when I turned the advance traction control off..
Quote from: Black Coyote on September 25, 2014, 07:11:18 AM
Any dtc with it?
Black Coyote
Diagnostic trouble code. You can pull these up with tuner or monitoring device (torque). Looks like the F150 guys have issues with a rear wheel sensor causing this.
Black Coyote
OK I'm check it after work. It came on a while ago..I turned the car off then back on and it went away, so I figured maybe just a glitch.
Same sounding thing, after some full turns triggering it, then it'd go away.
I wonder if the dtc that pops up for this would be same for each wheel or be able to pinpoint which one it is?
SHOnUup is correct check to see if there are any codes first,it happened to me one time and there were so many codes due to OBD MX bluetooth causing intference,so honestly would not worry to much yet,like mentioned before could be a GLITCH,try to clear the codes&hopefully they dont come back.
Also saw something about "steering wheel position" sensor, but that thread died with no confirmation.
Quote from: SHOnUup on September 25, 2014, 07:56:58 AM
THATS A B100 steering angle postion senor,lol
Black Coyote's issue is his wheel hubs and tsb washers need to be replaced,also happened to me getting DTC CODE B-1OO,steering angle sensor at wot,after performed the hubs and washers there are no more codes,all related to the front end.
