Started by Black Coyote, August 27, 2014, 09:01:19 AM
Quote from: ZSHO on September 25, 2014, 08:13:25 AMBlack Coyote's issue is his wheel hubs and tsb washers need to be replaced,also happened to me getting DTC CODE B-1OO,steering angle sensor at wot,after performed the hubs and washers there are no more codes,all related to the front end.
Quote from: ZSHO on September 25, 2014, 10:05:57 AMThe thrust washers are on the half shafts and usually the dealer would only replace the hubs,bearings.
Quote from: Black Coyote on October 05, 2014, 02:22:31 PMWhat oil do you guys run in the SHO's ?
Quote from: SHOnUup on October 05, 2014, 03:06:36 PMNot a drop. Went with OEM filter also. I have changed the oil twice now at 4k intervals.Rich
Quote from: bpd1151 on October 06, 2014, 01:12:30 AMGreat link!Excise what you choose to, but read ALL THE REST OF what was/is published in the link.
