hi, trying to find the previous owner or at least figure out my new 2013 SHO
Started by Black Coyote, August 27, 2014, 09:01:19 AM
Quote from: Black Coyote on September 04, 2014, 09:22:00 AM
From right to left engine bay pics without the cover. Looks stock to me under there...
The 1/4 breather hose suppose to be under the turbo pipe,just disconnect that tiny clamp and put it under,easy peasy,looks good,like the milti contour seats and i think its an extra 595.00 option.
Quote from: ZSHO on September 04, 2014, 09:51:20 AM
Noticed this also.
This pic from BiGMaC's SHO may help:
http://www.ecoboostperformanceforum.com/index.php/topic,3614.msg55966.html#msg55966
Most likely change happened when adding the methanol injection system (see the white tubing running under the intake, behind the HPFP).
Black Coyote
If you can show me a pic of where I'll see if it can be put under, but I believe I know what part your referring to.
Black Coyote
Black Coyote
Quote from: BiGMaC on September 04, 2014, 01:40:11 AM
Quote from: Black Coyote on August 29, 2014, 09:19:00 PM
The guy says he doesn't think there's a 3 bar on it... but he asked the tuner for more information so I'll get the full details soon.
Just look at the part.... Here's pics:
http://www.ecoboostperformanceforum.com/index.php/topic,3441.msg52193.html#msg52193
Appreciate this thank you.
Right under the turbo pipe,I added some extra 1/4 red mini clamps on all the 1/4 breather hoses for extra precaution.
wasinger3000
Quote from: SHOdded on September 04, 2014, 10:21:22 AM
Looks like the  vacuum line... could haven been routed a lot cleaner imo.
13' GTCS, will be missed.
Black Coyote
Zsho OK I see.  Thanks shoNup! I like it a lot.  I kinda want to put spacers on the wheels tho so the tires aren't sitting so far in but Idk if that's such a good idea.
Black Coyote
They do look good out a bit more, but that just makes me think about extra debris getting kicked up onto side of car.
What size tires do you have on there,are they the original Goodyear F1,if so how many miles and you could tell alot about the vehicle in reference to the wear and condition of the tires if original.
Black Coyote
Yep I believe they are the F1's, and the car only had 18k when I got it and now it's 19..so the tires are fresh.  I'll look at the size when I get to the car
