Started by ShoBoat, August 12, 2014, 09:48:56 AM
Quote from: jtoddk98 on August 28, 2014, 09:42:38 AMCan I use the sp534 plug instead of the 528? I have a 2011 carSent from my iPad using Tapatalk
Quote from: ShoBoat on August 20, 2014, 04:58:09 PMQuote from: crash712us on August 20, 2014, 04:39:05 PMGood info shoboat. I wish I knew more about ignitions or at least more details on coils and such. Cause narrowing the gap has its draw backs as well. Wider gaps have faster and flame propagation, but I have yet to see any spec's on the stock coils or even after market ones. And would more voltage allow you to run a larger gap and not have spark blowout. Ive seen testing on how spark gap has a big effect on efficiency and emissions.Yup, and also idle quality. I have noticed that the idle is a touch rougher at .30 than .32.Sent from my iPhone using Tapatalk
Quote from: BiGMaC on August 28, 2014, 10:56:40 AMQuote from: ShoBoat on August 20, 2014, 04:58:09 PMQuote from: crash712us on August 20, 2014, 04:39:05 PMGood info shoboat. I wish I knew more about ignitions or at least more details on coils and such. Cause narrowing the gap has its draw backs as well. Wider gaps have faster and flame propagation, but I have yet to see any spec's on the stock coils or even after market ones. And would more voltage allow you to run a larger gap and not have spark blowout. Ive seen testing on how spark gap has a big effect on efficiency and emissions.Yup, and also idle quality. I have noticed that the idle is a touch rougher at .30 than .32.Sent from my iPhone using TapatalkI wish we could readily find this data... And I wonder if there are parameters beyond timing that the ECM controls related to spark. I my SP534s are gapped at 0.30, but I have experimented with gap due to slight vibration at idle which resolves with an extra 100 rpms at .030... Interestingly this is only after the O2 sensors are warm and the slight vibration is not present in open loop operation when I start cold initially. This resolves at the increased gap of .032. I stayed at .030 based on Dan's recs.
Quote from: Brucelinc on August 28, 2014, 11:13:10 AMManual says .033-.037 on SP528s for a 2013 SHO.
Quote from: BiGMaC on August 28, 2014, 11:20:10 AMQuote from: Brucelinc on August 28, 2014, 11:13:10 AMManual says .033-.037 on SP528s for a 2013 SHO. Strange.... Mine came with SP534s ... But we've found a number of things like this in the "combo" manual Ford puts in the glove boxes of both MKSs and SHOs.... Even features not available on SHO at all, LOL
Quote from: ZSHO on August 28, 2014, 11:22:07 AMQuote from: Brucelinc on August 28, 2014, 11:13:10 AMManual says .033-.037 on SP528s for a 2013 SHO. MY original SP-528 which came from the factory were gapped at 0.35-0.37.
Quote from: Brucelinc on August 28, 2014, 12:02:18 PMThe plug type must depend on the build date. The 2014 manual calls for SP534s gapped at .033-.037.
