January 28, 2020, 07:28:45 PM
Author Topic: "How-To" SHO and Flex convert to vent to atmosphere with factory blow off valves  (Read 709168 times)
Offline EcoPowerParts
  • How can I help you today?
  • : Phoenix
  • -Given: 147
  • -Received: 1191
    • EcoPowerParts
I just converted my factory BoV to FTA on my Flex today.
What does this do for you?
Nothing but making a PFFFFT noise when you lift the throttle under boost.
Is there any downsides to this?
No, the car is speed desnsity so releasing the air from the turbos to atmosphere when the blow off valves open does not negatively impact the tune, factory or modified.
BTW, I couldn't find 1" vacuum "nipples" to block off the factory tubing so I went to Home Depot and searched around, found some 1" rubber chair leg "tips" to use, worked pretty good so far.
Front Blow off Valve and blocked off tube
Another shot of the factory Blow off Valve with the return tube removed - vent to atmosphere
Close up of rear portion of intake tubing with blow off valve return hose removed and blocked off. For me easiest way to get to this area and remove tubing was to remove the intake tubing and rotate to access the clamp that held the tubing onto the blow off valve.
Rear Blow off Valve
Complete turbo to intercooler pipe with Blow off Valves circled
EDIT: Found some rubber caps to use instead of rubber chair leg bottoms
http://www.mcmaster.com/#92805K28
Updated pictures with the new caps on from mcmaster - didn't know they were going to be red :(
« Last Edit: July 14, 2013, 09:58:42 AM by 4DRHTRD »
Offline PopolZ
  • Full Member
  • : Saint-Hubert, Qc - Peoples Republic of Canuckistan
  • -Given: 6
  • -Received: 10
  • Ecobooster & RB26ster
On the SHO we already have the PFFFFT because of the "noise generator". Mine is sitting in the trunk since it's been replaced with an HKS SSQV III BOV.
2010 Ford Taurus SHO, non-PP, Steel Blue #243 of 301 - Custom tune by Torrie@Unleashed, PPE non-catted downpipes, custom 3rd cat & resonator delete, water/meth injection, HKS SSQV3 BOV and Carbotech AX6 brake pads.
1991 Nissan Skyline GTR, Pearl Black Metallic - a few goodies
Offline bnoon
  • Full Member
  • -Given: 0
  • -Received: 6
I just disconnected mine last night and took a trip around the block to make sure it didn't have any issues before I started buying intake parts.
Offline EcoBrick Bob
  • : Naples, FL and Clear Lake, IA
  • -Given: 64
  • -Received: 102
WHY?
"What difference does it make?"  (H. Clinton)  LOL :bangin:
Naples, FL & Clear Lake, IA
  • : Phoenix
  • -Given: 147
  • -Received: 1191
    • EcoPowerParts
I just looked up an article on the BoV installation on your guys car.
So, now I'm looking at buying a SHO intake tube that goes from TB to IC and then have Paul make a tube that replaces the SHO/Flex back turbo to IC tube with no holes in it for BoV.
This way an aftermarket BoV can be added to the intake tract and the factory BoV can be removed entirely.
We're looking at a way to make a plug and play resistor to replace the factory BoV as well so no CEL
Hmm that part is AA5Z-6F073-B - $110... More research to do :)
« Last Edit: May 09, 2013, 07:39:30 AM by 4DRHTRD »
Offline bnoon
  • Full Member
  • -Given: 0
  • -Received: 6
WHY?
The reason I'm doing it is to make super shorty intakes, basically just filters on the turbos. I don't care about IAT, only boost temps. This will simplify and eliminate a lot of hardware real estate under the hood for when I go liquid to air intercooler.
  • : Phoenix
  • -Given: 147
  • -Received: 1191
    • EcoPowerParts
WHY?
Keep me in the loop on this, I'm looking at doing that after I get fueling/turbos installed in a month or two.
  • : Phoenix
  • -Given: 147
  • -Received: 1191
    • EcoPowerParts
Flex Ecoboost - BoV set to VTA
Video
Offline bnoon
  • Full Member
  • -Given: 0
  • -Received: 6
WHY?
Sure will. Do you know the turbo's factory inlet diameter? Looks to be around or just under 2 inches but I can't tell for sure without disassembly.
  • : Phoenix
  • -Given: 147
  • -Received: 1191
    • EcoPowerParts
I don't think even 2", I'll have my stock-upgraded turbos back soon I'll take a measurement. In discussing the factory IC, I think I can pick up another 30+HP just by going with a water to air IC, I've been considering installing the heat exchanger in place of the factory IC as there will be space there, just need to find a core that is sized appropriately for that.
I'm going to be putting my water resevior in the rear spare tire area, I'm going to have a custom nitrous tank/water resevior built for back there when I do the IC upgrade.
Offline bnoon
  • Full Member
  • -Given: 0
  • -Received: 6
Since I don't go full bore racing with mine, I won't even have a remote resevoir for mine. Just the largest h\e I can fit and a small overflow bottle for the pressure release lid.
  • -Given: 64
  • -Received: 102
Don't quote me, but I think I remember Darreli saying the inlet is        1 1/2" as the Hennessey CAI system he bought a couple years ago didn't have a reducer/taper and just went from 2" to 1 1/2".
  • -Given: 64
  • -Received: 102
With your nitrous system you might get that extra HP, but my MCT temps running 75% methanol went below outside temp, so not sure how much cooler one could go with liquid IC, unless the liquid would be at a temp much below ambient.  Guess one could cool it with A/C system..
  • : Phoenix
  • -Given: 147
  • -Received: 1191
    • EcoPowerParts
Another video
Another video of factory BoV VTA
  • -Given: 64
  • -Received: 102
I would do this only if it will make "LOUD FART SOUNDS"... :biggrin:
* Featured Topics
* Recent Topics
Re: Post a Pic of your Ecoboost!
by StinkinLinkin13 | January 27, 2020, 11:05:34 PM
Gray day beads.. ...
Re: New Bro
by ridered74 | January 27, 2020, 08:37:32 PM
Little update. Wednesday she is going to the local performance shop an...
Re: Phenolic Spacers
by 802SHO | January 27, 2020, 05:00:14 PM
I sent an email too!  Figured might as well right?  Hopefull...
by bpd1151 | January 27, 2020, 01:15:34 PM
ATP's scrapped. GH turbos now planned. They should be getting my ...
New Filters & Rebates at RockAuto.com
by RockAuto | January 27, 2020, 01:04:33 PM
ACDelco Filter Rebates:Save even more on RockAuto's reliably low ...
by bpd1151 | January 27, 2020, 12:32:11 PM
01/27/20......Placed an email inquiry to x35 Designs, in regards to th...
Re: RockAuto Discount Code for Parts & More - Expires March 30, 2020
by skippytx | January 27, 2020, 11:12:09 AM
Thanks for the discount code all.  Saved me 15 bucks on my pads ...
Re: 2014 Lincoln MKS EcoBoost with all the goodies $14,900
by Nova | January 26, 2020, 08:54:58 PM
I actually plan to do exactly that, but at the drag strip here in Orla...
Re: In car temp sensor rattle
by IGottaShoYou | January 26, 2020, 03:52:05 PM
I can't say anything on your, but most of the interior temp senso...
Re: 2013 SHO Suspension Work
by ZSHO | January 25, 2020, 02:10:31 PM
Yes it is routine to replace the hub nut every time the old one is rem...
Re: Friction modifier in rear end
by SHOdded | January 25, 2020, 12:39:49 AM
No.  The clutch pack is sealed, and only the gears are serviced w...
Re: Auto tilting reverse mirrors working help?
by jdsfel | January 23, 2020, 04:36:38 PM
Hey @Gjkrisa,  did you ever get this working?  I am planning...
DIY dual Amazon catch can
by ChrisxHowe | January 23, 2020, 02:33:28 PM
Made my own catch can set up with 2 catch cans from Amazon and some 1/...
Re: Quality time with my Son washing the Lincoln
by PDSHO | January 23, 2020, 02:10:45 PM
One year we took a vacation to Yellowstone when I was a kid, my only r...
My car hates me
by Spyder3000gtvr4 | January 23, 2020, 12:20:09 PM
So 5k later cars finally on the road with a bit of new parts and of co...
Back to top
