SHO-TYM,if your stat didnt come with an o ring use the original one when you swap them,cause my 170-stat came with an o ring,regarding install you will have to remove the airaid out,and honestly car has to be cold,the longer you wait the better,less coolant loss,8mm socket and 2 bolts and check your recervoir later,easy peasy.
