Shortly after having my PPE catless downpipes installed and tune changes made, I started to have some white/blue smoke coming from the passenger side exhaust only. It only does it if I am running the car hard and into the boost and then when I stop there will be substantial smoke behind the vehicle. I had my mechanic take off the downpipes and he thinks that the turbo on that side is not blown and is reinstalling the stock downpipes as I write this. The car also has not thrown a single code.
I have a read a couple of threads across different forums including this one, where this very same problem has occurred after putting catless downpipes on to a car, but there was never any closure on the cause or if just throwing on the stock downpipes solved the problem.
I would like the experts out there to weigh in on this to see if there is a reasonable solution to fix the problem before I strip the car down to stock to bring it to the dealer to roll the dice with their diagnosis.
Any and all help is much appreciated.
