Scott4957
#3000
Installed the Snow stage 2 kit this weekend. Am I the first MKS with meth? Anyways just need to plug the power wire into the add a fuse and run the LED wire into the cab and I am finished. I purposely didn't buy any M1 because I knew if I had it I would rush the install. Performance report and a how to will be on it's way in the next couple weeks.
2013 Lincoln MKS EcoBoost, AJP Tuned
CroR1
Seems like you had a fun weekend, congrats!! looking forward to seeing the how to with pics.Did you use the factory washer bottle for the reservoir?
Quote from: Scott4957 on April 24, 2016, 09:40:58 PM
Installed the Snow stage 2 kit this weekend. Am I the first MKS with meth? Anyways just need to plug the power wire into the add a fuse and run the LED wire into the cab and I am finished. I purposely didn't by any M1 because I knew if I had it I would rush the install. Performance report and a how to will be on it's way in the next couple weeks.
Scott4957
Quote from: CroR1 on April 24, 2016, 10:19:30 PM
Yes, I took the bung off the snow tank.and used it on the factory washer tank. I took care to document this well.
:worthlesswithoutpics[1]: :lol: :lol:  Z
KonaTheWhale
Quote from: glock-coma on April 24, 2016, 08:51:24 PM
Quote from: KonaTheWhale on April 24, 2016, 07:35:45 PM
Finally put on the EBC brake pads and rotors, excited to see how much of a difference the are from stock brakes! Also don't mind the peeling plastidip the rims will be painted soon
Be sure to break the pads in by the book or you will toast them.
I am definitely trying to take it easy on them, at least as good as I can driving in the city/highways. Hoping if I have to get on them on the highway for any reason I'm still good, guess I will find out
2011 Ford Taurus SHO non PP Kona blue, Livernois 93 octane 3 bar tune, PPE catless downpipes, muffler delete, 160* stat, K&N drop in filter, VTA mod, rear end lowered, 15% tint, EBC brake upgrade
Scott4957
BBOX
Brucelinc
So Scott, when are you taking that beast to the track to see what it will do?
Scott4957
Quote from: Brucelinc on April 25, 2016, 12:54:04 PM
Still plenty if tuning to do with Torrie! I am waiting for some great DA in the fall since I was too late for the spring.
Fmrfordmastertech
#3009
Just changed the oil in the mkt. Installed new thermostat and changed the orange coolant. I had the ford oem stuff for ten yrs! Used to be a linc/merc tech . Finally got to use my stock!
2013 linc mkt ecoboost
Welcome to EBPF, Fmrfordmastertech, glad to add another MKT owner to our ranks :thumbsup:  How much stock did you say you have, and which warehouse :D
Please do introduce yourself and your ride in the new member area ...
I just had my Local friendly Ford Dealer perform a brake Flush and an oil change which took roughly two hrs to perform and quite honestly saw a significant improvement in braking with a much firmer brake pedal feel,think a brake flush was certainly needed at just hitting 40k on her and the total was less than 40.00 using my own fluids and also purchased two spark plugs included in the price.  Z   :)      http://www.amazon.com/Motul-8068HL-Factory-Percent-Synthetic/dp/B004LEYJO4?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00  BTW for anyone wondering two bottles are needed.  Z
irondoor19
#3012
Pre Drag Strip:
So i had the time and Pole Position at the Light (leading to a 2 Lane Freeway)
Testing out the New DashCommand, the ODB2 (IcarII), and an ipad 1, Leading to
the Following Results., Do not know how Accurate this is, But It Felt Really Good
and I have changed my Personal Pic Accordingly... Hoping to get to the track this
weekend ;D
AS i am Way new to this Direct Connect Stuff, and just stopped Running DOS based
Cad end of last year, I do not even know Enough to Answer that Question.... HA
2010 Lincoln MKS, BONE Stock for Now, 2014 3.7L Police, Drop IN K&N,
@ irondoor, what do you have bsfc set at in dash command?
salsathe4th
Just got my left lower control arm and bushing replaced....out $600 bucks and they showed me the other side while on the lift and the bushing is going bad on the other side too. They said when they change the other bushing they might as well change the other control arm too. We'll see when I get that done.
"Do or do not, there is no try"         2010 MKS, 22" Motiv Maranello Rims, Mdesign CAI with VTA, LMS 4X tune and lovin' it
-master yoda
