Jordan
802SHO
Jordan
Quote from: 802SHO on August 29, 2019, 09:07:29 PM
Quote from: Jordan on August 29, 2019, 08:56:15 PM
Lol y'all got me feeling young at 25
Haha!  I wish I was 25 again
To put into perspective. I built one of these ecoboost SHO's on the ford website as a freshman is high school...
Quinid
Took Flex to the stealership to replace the driver side outside door trim with the keypad. They had to remove the internal door panel and the glass to replace it. To anyone else owning a Flex, if that trim is starting to come loose, replace that double sided tape immediately. That is the only thing holding that thing to your vehicle. It will rip off at interstate speeds on a hot day and damage your paint quickly as it hangs by the wiring in the wind.
2014 Blue Flex 303A Appearance package all stock
2000 F250 XLT 7.3L 410k miles
SOLD--2010 nonPP SHO  Unleashed 93 tune, 3 bar map, K&N drop in filter. PPE Catted Downpipes. VTA mod
1957 Chevy 3200 pickup 3 speed stock straight 6
1968 Camaro RS 3 speed 350 sb with vortec heads.
76fomoco
Quote from: SM105K on August 29, 2019, 08:47:50 PM
Hahah I turn 35 on Monday.
wow I would love to be 35 again! 47 in 40 days....
You will be 47 in 40 blinks of an eye!
2013 PP AJP E30 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35, EPP hot and intake
Best 3-29-21  11.85 with 3000 DA
DA trap best 117.96
E30 = 492 whp, 536 wtq
E30+meth 498 whp, 539 wtq
SM105K
Quote from: 76fomoco on August 29, 2019, 11:51:45 PM
Don't you put that evil on me!!!!!!!
God put me on this planet to accomplish a certain amount of things.  I am so far behind, at this rate I will never die!
802SHO
802SHO
Taking the SHO to New England Dragway today for some before and after Nitrous tests.  I'm going to weigh it and see how much it is with me in it full weight.  Then hopefully beat my 11.89 at full weight before nitrous.  Then I'll see what improvements can be made with the 35 shot full weight.  I'm going to go max effort(weight reduction) at the end of the season.
Jordan
76fomoco
DA trap best 117.96
shoNoff
Quote from: SM105K on August 30, 2019, 08:54:13 AM
All I can think of
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
shoNoff
Quote from: 802SHO on August 30, 2019, 09:23:54 AM
As I told you this morning I'm doing my best to get there tonight. Hopefully I can get up there around 630/7 but we will see how it goes. If not good luck buddy and keep me informed.
shoNoff
DA looks like it should be between 1200-1500ft tonight. I'm heading up after work to make a couple edge passes and watch Andrew. I will give horribly encrypted updates just to string you jackals along.
802SHO
802SHO
Nothing but oil down after some moron hit the sand trap at the end.  Been here almost 30 min I saw 6 cars go down the track.  Tim has been here for an hour hasn't gone yet.  And Tim saved my ass the Fire Jacket is what I needed!  They didn't even check the bottle.  Icing the intake manifold but I should probably ditch that idea and just go get in line.  So maybe I can go once...
