shoNoff
#6750
To be honest there is actually LESS room back there for the clubs then the sho. I see this whole thing ending a year from now. Me sitting at the ford dealer with a broken edge sport trading it in. All while my wife stares at me shaking her head saying "I told you that you were gonna mod it and break it"
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Jordan
Quote from: shoNoff on July 30, 2019, 10:02:48 PM
To be honest there is actually LESS room back there for the clubs then the sho. I see this whole thing ending a year from now. Me sitting at the ford dealer with a broken edge sport trading it in. All while my wife stares at me shaking her head saying "I knew told you that you were gonna mod it and break it"
LOL, hit me up for that weight reduction life on drag strip days!
SM105K
Resistance is futile.
802SHO
Funny part is he'll still mod it but hopefully not break it....he got it early enough 33k?  Yeah with good maintenance you'll be alright
76fomoco
you know there is always the one kid who can break the anvil in the sandbox.... most of the time it's me :)
2013 PP AJP E30 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35, EPP hot and intake
Best 3-29-21  11.85 with 3000 DA
DA trap best 117.96
E30 = 492 whp, 536 wtq
E30+meth 498 whp, 539 wtq
shoNoff
#6755
In not sure how far I'll mod it. I usually can't control myself once I start. The baby coming has me thinking "be smart don't break it." But my right foot says "boost launch this b*tch to 12's!" We will see where I end up after the first round of mods. I will say this the edge sport is miles ahead of the sho to me in build quality. Everything just feels tighter and better materials then the sho did. Even the leather feels nicer. The Sony system in this thing blows the sho out of the water. It's not even close. Also sync 3 is one of the best systems I've used in a car. The sync 2 in my old sho was easily one of  the worst I had ever used.
Jordan funny story before your post I was thinking. Man how much weight can I take out of this thing.
Andrew man I really hope I got a good one this time. I can't go through the sho stuff again
76fomoco we are cut from the same mold brother. If they say it can't be broken give it to me.
I installed a new PCV Valve today for a peace of mind! I think sometimes we neglect to replace such a vital component especially at its price-point!
Disconnect the crankcase ventilation tube-to-PCV valve quick connect coupling.
NOTE: To install, apply clean engine oil to the O-ring seal.
Rotate the PCV valve counterclockwise and remove from the crankcase vent oil separator.
To install, reverse the removal procedure. Install a new PCV valve and enjoy! Z  :)
Motorcraft AA5Z6A666D
https://www.rockauto.com/en/moreinfo.php?pk=2313610&cc=1503823&jsn=8
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,exhaust+&+emission,pcv+(positive+crankcase+ventilation)+valve,5052
76fomoco
Quote from: shoNoff on July 31, 2019, 12:11:27 PM
my sho is my wife old car and now she has a 2018 mkx with the 2.7tt hummmmm
DA trap best 117.96
Jordan
Ha, I thought the first time I "stripped" the car was a lot. This last time was another hundred pounds easily over what I had done previously and now I am scheming a little more... Bring it to me and the suspension would look like you got a lift afterwards! LOL. Those interiors are pretty beefy that's for dang sure.
TopherSho
Not to give you a heat stroke in your garage ..
but you should weight out the larger bits you pull and post them.  it is surprising what weighs what ..
The passenger and back seats alone have to weight 100+lbs..
the freaking inch thick floor mats in mine weight 9 pounds
A drop in capacitor ''battery'' would save 30 pounds..
Best 0-60 public road 4.35s
TopherSho
Quote from: SHOdded on September 01, 2018, 03:41:12 PM
helps to take the weatherstripping off at the firewall. and to pop the hood when the run is over and you are cruising back to the line.
This.  Been doing it for every performance car for years.
for the SHO also drop to manual and drive the return lane in 2nd to increase rpm and air flow through the throttle and cooler water.
Jordan
Funny you mention lighter battery the OEM replacement one kicked the bucket on me couple months back. Replaced with a lightweight Braille battery. Saved twenty lbs that way. I've thought about weighing stuff but honestly just get into the zone on getting everything out. Can have it done in a couple hours tops now.
802SHO
SM105K
Jordan
Quote from: 802SHO on August 02, 2019, 12:20:57 PM
Getting ready to head to New England Dragway
Expecting a new record from you! You got this
