SM105K
Quote from: SHOdded on June 26, 2019, 04:12:29 PM
glock-coma did the wheels on his 2010 in copper IIRC.
I do like the copper wheels on black and Subaru Blue cars.  They look sharp.
802SHO
Since getting my front chin spoiler damaged at the dyno shop from backing into a truck axle......I sent it out for a respray in Tuxedo Black of course and I couldn't resist having my new Ford Emblem from Billet Badges sprayed as well in the beautiful Tux Black!  Picked them up and hopefully back on the car this weekend.
SM105K
802SHO
802SHO
Black Dream
Headed outside in a bit to coat the car with Optimum Gloss Coat.  Spent 6 hours prepping my MKS for the final coat Monday and finally have a break in dreary, rainy weather to finish with the ceramic coating.  I did the same last year to my dearly departed GTO and the results were amazing.  A year later the shine and hydrophobic properties were unchanged on the Goat and I expect the same with the Lincoln.  As a big fan of the Optimum line I can't wait to see how the MKS turns out.
Here are a couple of untouched pictures after I finished the GTO:
2010 MKS Eco, Airaid, SCT X4, Unleashed, SP542 plugs, 3 bar MAP and current daily.
2006 Pontiac GTO M6, 1 of 101 exactly like her, bone stock, lost to flood 5/19, gone but not forgotten....
Ford paints usually turn out pretty good, and this should be no exception.
This is regular old rattle can over anthracite  plasti-dip.
Jordan
Heading to the drag strip with a couple other sho owners tomorrow. Going to run full interior for once lol
SM105K
Quote from: Jordan on June 27, 2019, 12:17:09 PM
You should rethink that.  You might be too comfortable....
Jordan
Lol, bringing my fiancee otherwise car would be tin canned
76fomoco
you should come to our track day Saturday  4200 da and full interior I bet I will run 12.6-12.7  :(
2013 PP AJP E30 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35, EPP hot and intake
Best 3-29-21  11.85 with 3000 DA
DA trap best 117.96
E30 = 492 whp, 536 wtq
E30+meth 498 whp, 539 wtq
Jordan
Quote from: 76fomoco on June 28, 2019, 12:46:50 AM
Suppose to be 4k da tonight lol
