SM105K
Quote from: bpd1151 on February 04, 2019, 09:34:59 AM
I'm a lil jelly there sm105k......
Great addition to the stable!!
Enjoy.
Thanks BPD.  I am really impressed with it.  Going to keep it stock, and really start modding the SHO.
Learn to exhale forcefully.  You will fit 100% into the Recaro seats.  LOL
SM105K
Quote from: SHOdded on February 04, 2019, 10:12:08 AM
For what I do, I am pretty light in my weight now.  Now if I could be a bit less fat....haha.
I did make a post earlier and will need to update soon,but the new updated Low level sensor is NOT compatible and the plug does NOT fit the new harness on sensor.  Z
Mid page for reference.
https://www.ecoboostperformanceforum.com/index.php/topic,299.6030.html
lamrith
#6049
Nother day playing snowmobile.
Here in the PNW we rarely get snow.  We got hit with 3-5" sunday night.  roads were all packed ice/snow by the time drive to work came around.  I was a bit nervous given I am running 275/40-20 GMAX AS-05's now, big wide tire to be running in snow.  Rollers like that tend to float ontop of snow and not be great.
Car handling it awesome.  I respected the conditions and did not throw her around like I normally do, but had no issues with sliding etc.  Same thing this morning, 11* everything frozen solid and all i had to do was point her and go.
Maaaannn does she need a bath now though.
Macgyver
Quote from: lamrith on February 05, 2019, 02:59:36 PM
Nother day plaing snowmobile.
Yep. Not perfect traction but she still goes in the snow with these tires. Next year will test them. Worn AS tires are either good or crap the next season.
lamrith
Once more into the breech for the snobeast.  1st of two storms started bit ago and already covered everything with that nasty slick wet white stuff.  Wish it was colder so it did not pack into ice so well.  :-/
Clowns here have no clue how to drive in snow.
Jordan
Well, got another revision from Brad today. Really learning how crazy efficient this intercooler is. With temps WELL below freezing we are just having to dial back the boost more and more. With the most recent log being at 15 degrees ambient with only 13psi in a non heat soaked scenario (not like that matters much anymore) the stock hpfp just isn't keeping up very well. Dialed it back even more. Still making GOBS of power it feels like though. Going to be really crazy once the weather gets nicer. Really want to invest in an upgraded hpfp when I have the funds, but that won't be for a hot second. lol Honestly I just want some nicer 70 degree weather because holy crap it's been frigid.
Colorado-SHOBro
Quote from: Jordan on February 09, 2019, 02:12:04 AM
Yep i'm not in any hurry to install mine for this reason. Good to hear the positive results though! What did your boost #'s and FRP look like with the stock IC? are you just running 93octane and the HPFP isn't keeping up?
11' SHO Tuxedo Metallic black-non PP | Highly sophisticated high altitude custom AJP Turbo E30 3Bar tune w/Wastegate mod | Cat'd ceramic PPE downpipes |170 stat| SP542 plugs .028 | PP trans cooler | H&R springs | RX catch can
12.8@108 @ 6,000ft DA.
Jordan
I can't exactly tell you because the weather has been so extremely frigid and temperamental is hard to give a direct comparison. Stock hpfp struggling to keep up at 13psi with iat2s in the twenty ranges. Intake temps decrease now with acceleration instead of increasing now so puts extra demand on the pump. Once everything is warmed up and tuned in I want to see what the limitations of the stock hpfp are at the strip before I go upgraded. Hoping for an 11.7 with everything i got now. If only the spring would hit mid Missouri asap lol
StealBlueSho
Just grab an upgraded HPFP... after that who cares about temps ;-) run one tune and call it a day...
This Firestorm pump just runs... upgraded IC installed.. E30(although I'm running probably E40 based on my trims). 10F outside... perfect fuel pressure all day long..
It's just money....
StealBlueSho
Side note... ordered PPE Catted DPs with the thermal coating the other day... pretty much ends the easy bolt on stuff...
Need to decide if I am gonna go any further... turbos would potentially be next, maybe a circle D torque converter, maybe just do both? Eventually a motor build would be required for safety...decisions decisions...
Scheduled to get the windows tinted on Monday...not go fast but needed...
AJP turbo
Quote from: StealBlueSho on February 09, 2019, 08:17:37 PM
It's just money....
Not everyone has another $1600 after buying the 800$ intercooler money bags lol
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
Sometimes the non-go fast additions, make the ride just as enjoyable as the actual go fast parts do.
All steps towards a total/complete build/package.
