I just ordered a set of Motorcraft SP-534 Spark plugs from
our very own https://www.rockauto.com and probably have them installed prior to heading to the Track for added measures....Z  :drive:
   Part Number   Part Type   Price EA   Core EA   Quantity   Total
2013 FORD TAURUS 3.5L V6 Turbocharged
MOTORCRAFT   SP534 (SP-534)   Spark Plug   $ 6.53   $ 0.00   6   $ 39.18
Discount       $ -1.96
Shipping   SmartMail   $ 3.99
Order Total  $41.21
5% Discount Code: 3BA67137D2BE4A
Expires: December 21, 2017
StealBlueSho
Second that!!! Can't wait to see what that beasty can do!!!
irondoor19
Quote from: SHOdded on September 30, 2017, 01:32:17 PM
Ugh.  Goodridge SS hose or some other brand?
Yea: Goodridge....., We will see about any warranty, a tad scary as well
2010 Lincoln MKS, BONE Stock for Now, 2014 3.7L Police, Drop IN K&N,
Mpcop68
Hi ,just joined the forum today. I've had my 2010 SHO for about a month and a half now. I went with the cold air intake, 3 wire airflow sensor, the programmer and down pipes along with a 160 thermostat. I was wondering if your car felt like it was running hotter after you installed the thermostat. Mine feels like its running hotter although the gauge doesn't indicate so and my fans kick on rather quickly. Any thoughts? Thanks.
Quote from: Mpcop68 on October 02, 2017, 01:08:24 PM
I would check your coolant reservoir to make sure its full preferably above the TOP Fill LINE when the car is cold in the am.
The 160-stat kicks on more often but stays on for a shorter period of time.IIRC. and is working as designed IMO. Z
How much coolant did you loose?
AJP turbo
What is a 3 wire airflow sensor?
And the 160 Tstat shouldn't have anything to do with the fans alone...In fact if you are not running a tune then the fans would run less...If the radiator was efficient enough then you would not even need fans..Fans are a supplement and for optimum use of a thermostat programming is required because our radiators do not have the capacity to provide the level of cooling that a 160 thermostat is trying to operate at.
If you fans are over active then maybe they are set too low...Fan speed must be set about 5-10 degrees ABOVE the temp at which the thermostat is FULLY open...Many people struggle with the concept but if you have a 160 stat you really don't want the fans to come on at 160...Otherwise they are trying to cool to a temp that is never possible because the stat is not open.
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
boosted4SHO
Installed LED puddle lights. My driver's side mirror puddle lamp was blown so I figured why not upgrade.
CW III
2011 non-PP SHO - tuxedo black
custom CAI w/Green Filter, SP534's @ .030, JLT catch can, switchback LED's, 20x8.5 +35 Ruff 959
in the works...
Quote from: AJP turbo on October 02, 2017, 01:52:55 PM
I think he has a programmer and a 3bar map!!! maybe,perhaps!!! lets cut the Newbie some slack Lol.  Z
lamrith
Did puddle lights on the sho.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Gjkrisa
Quote from: lamrith on October 02, 2017, 10:55:50 PM
How do you like it I like the idea but feel it may be a novelty item that soon after might be disappointed
lamrith
Quote from: Gjkrisa on October 02, 2017, 11:27:32 PM
I like it, has good area lighting beyond the logo, so it is fitting both uses.
