irondoor19
Last look at the Bad Cylinder and Piston,
Brought back to the ford dealer for the Core.....
2010 Lincoln MKS, BONE Stock for Now, 2014 3.7L Police, Drop IN K&N,
Lexingtonian
Quote from: irondoor19 on May 24, 2017, 02:39:03 PM
Oh Crap! How that happen?
2016 Explorer Sport Metallic
93 Octane AJP Tune (SCT X4)
3Bar MAP
Plugs at .030
Lexingtonian
Added a 3bar MAP and my very first AJP Tune for 93 Octane..
3Bar MAP
Plugs at .030
TopherSho
Quote from: Lexingtonian on May 24, 2017, 05:46:20 PM
Root cause = heat.   Heat makes the piston rings expand, which is normal *until* they close thier gap all the way, after that the piston ring ends overlap .. the cylinder block and liner is stronger than the piston walls so the force of the overlapping rings is then directed onto the position  wall, that cracks a chunk off the piston and proceeds to grenade.   THIS example is weird in that no NOS was involved and the damage is quite minor.. (this is super common on non-preped engines running to much NOS, or not cooling enough), .  But in my head this is totally rings overlapping and bending the piston crown upward and fracturing stuff.
Best 0-60 public road 4.35s
hawkeye93
Got my ethanol tester yesterday, so I tested the local E85 supply.  Measured out at approximately E72.
Sent from my HTC One M9 using Tapatalk
2015 Ford Taurus SHO PP 12.219@112.84
PPE catless DP, Gearhead IC, SP-534, Reische 170, 3 bar, hybrid meth system, tunes from Unleashed, Livernois, Brew City Boost & AJP
1965 Ford Mustang Convertible 289 4V/T5Z/3.55
1955 Ford Fairlane Club Sedan 272 4V/Fordomatic
StealBlueSho
Quote from: hawkeye93 on May 25, 2017, 09:40:35 AM
That is significantly lower than E85......
hawkeye93
#3937
Quote from: StealBlueSho on May 25, 2017, 09:41:41 AM
Yes, pump E85 can be anywhere from E51-E83.
https://www.afdc.energy.gov/fuels/ethanol_e85.html
StealBlueSho
Quote from: hawkeye93 on May 25, 2017, 09:43:40 AM
Wow... I was under the impression that they were at this point quality controlled.... lol
FearlessAZ
Negative. It can say E85 but it has to be at least E51 or similar depending on the state. Arizona recently put out that all E85 pumps are now E55. But they are still labeled as E85 and will continue to do so. That is why it is necessary for the testing kit because the E% varies all the time.
StealBlueSho
Completely finished with Alky Kit Installation... tune(working on it..) and all....
Thanks to BPD1151 for the Alky How To installation guide, lots of good information.. such as which wire to tap for the MAP sensor and which fuse to piggy back off of on the fuse box.
Couple things to note...
1: The instructions recommend loctite for the nozzle fittings... I would recommend white plumbers tape.. the loctite leaked...
2: If you plan on using the supplied tanks for the windshield washer reservoir, make sure you cut the hole for the pump perfectly round.. or as close as you can get... mine leaked cause I screwed it up...
3: Going through the firewall, BPD's directions are pretty solid, but make sure you use at least a 1/2in drill bit, and make sure you go straight and as close as you can to the blue tab in his picture.
4: When testing the alky, it might take a bit longer than you would think for all the air to get out of the system and the ready light to go green..
5: If you buy a 5 gallon can of VP-M1, unless you are going to transfer it to a different contain... get some kind of pump to get it out with... crap goes everywhere even if you are a brain surgeon...
Initial datalogging is showing a significant decrease in IAT's.. over 30F drop... Current "Meth" tune from LMS has no added spark or boost, I have an email out to verify if that is correct. Car runs like champ though.
Congrat's there SBS!! Now Time to update your signature. Z  :thumb: :thumb:
FearlessAZ
Quote from: StealBlueSho on May 25, 2017, 10:58:07 AM
That 30 degrees got my attention. Hoping to do this next year. Can't wait!
Happy everything worked out, Steal!
StealBlueSho
Quote from: FearlessAZ on May 25, 2017, 11:53:24 AM
Thanks!! Install was fairly easy... only complications was a leaky nozzle due to incorrect sealer and a miscommunication on the tune. Time will tell if it was worth the money....
irondoor19
Done W the Engine Install, hood still off,
in case problems with the ECU...
Tow to the Stealer Dealer on Tuesday,
for a Flash, Battery and first time Start....
